if you had white smoke cause oil fell on the exhaust if they changed the gasket and did not clean it then you will still have white until it burns all of it off. what you should be check if around the edges of the valve covers to make sure no new oil is leaking and it if it take it back to the shop and have they fix it cause they did it wrong.
