Thread: Separate transmission manual for 1994 Galant
Showing results 1 to 2 of 2
    Looking at the transmission (auto) section of my workshop manual, I see the comment for Inspection Procedure 14:
    - Poor acceleration: While driving, acceleration is poor ... defective clutch or brake...Probable cause: malfunction of clutches, etc ...
    - Refer to the Transmission Workshop Manual
    Is there a separate Transmission manual? I can't find any reference to it online.
    Thanks!
    08-18-2004
    Charlotte, NC
    1,029
    Whats the problem? Is the CEL on?
    1994 GS FYI
    DSM/CSM Manuals
