if i were u, if u wanna go turbo, first of all get at least low compresion pistons and set of nice rings. Reson for that - it takes about 3 weeks to make them.
See also if u can save up some money for the stand alone rather than SAFC. This is really the best way to go.
Also, since your car is in the shop - i would probably contact level ten and see if they can rebuild your transmission so u can boost a lot of psi.
Tranny will be always an issue. I mean 300+ hp at the wheels - sound like Tranny will not take it. Also, 300+ at the wheels - I don't know about the connecting rods. That would be way more than 350 hp at the crank = rods will not hold it....
If u can fit in 5K for 300 Hp at the wheels than i gotta say 1 thing:
You are getting hooked up.
