Thread: Building a Electric Supercharger
Showing results 1 to 20 of 21
    I am planning on building a Electric Supercharger and Im Looking for a few tips from anyone who has done this before.
    At the moment my plans are to use a Vacuum Cleaner Motor or the water pump from a Old Washer. Haven't got around to planning how Im goin to make it work yet
    8th Gen Rox
    http://mynccruizer.tumblr.com/
    OBX Long Header 12" Visonik Subwoofers x2
    K&N Typhoon SRI 15" L7 Kicker Solo Baric
    3" Muffler
    Member NCamiolo's Avatar
    02-27-2010
    Cape Coral/Fort Myers, Florida
    253
    Not sure how I see this working. I have a feeling you are going to get a lot of shit for this.
    Lol? Anyone done this before? No one I know.
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    08-08-2004
    Las Vegas
    2,099
    in before the storm lol
    Im not sure how it will work either or if i will c any gains but i will find out soon enough
    8th Gen Rox
    3" Muffler
    TGC Regular foxbrand's Avatar
    06-18-2011
    chicago suburbs, IL
    600
    a vacuum cleaner motor? Unless your using a fan and motor from some massively powerful central vac set system, those aren't remotely large enough to provide enough flow to at least idle an engine, anoth major speed bump is that you also must make sure the fan blades (well, almost all are impeller designs anyway) are absolutely clean of dirt because it's out of the vacuum cleaner
    and yes I do know this, part of the services my work provides (we in general fix home appliciances and we sell cleaning supplies) is fixing vacuum cleaners
    Yeah I planned to Clean it.
    Reason I said I would use it is because i searched super charger on ebay and came up with this http://www.ebay.com/itm/3-JDM-SUPERC...f51093&vxp=mtr
    I figured a vacum motor would do more then that yes i know its the fuel saver but there are "superchargers" that look just like it.
    something like this is really my goal
    http://www.ebay.com/itm/Mitsubishi-I...90f91a&vxp=mtr
    8th Gen Rox
    3" Muffler
    engine spins alternator > alternator spins supercharger > supercharger spins motor faster!
    INFINITE POWER!!! MUHAHAHA
    and yes i do know how a supercharger works, but i really dont think any electric fan you put on it is going to be able to pump enough cfm at enough psi to do anything, it will just restrict airflow.
    lets say your cfm of your intake is 500, my 2.5hp air compressor makes about 10 cfm i think?
    that should put it into perspective..
    edit: well i guess the 10cfm is at 90 psi which would be way too much to boost but even still..
    07-16-2006
    Cocoa, Florida
    791
    like this?
    Awritey so more thought has to be put into this project/experiment what can I use to measure intake psi?
    8th Gen Rox
    3" Muffler
    The Dyson ball claims to have cyclonic suction.!!??? Wait that's the meds talking again.
    Flame on fellas!
    yea something like that.
    8th Gen Rox
    3" Muffler
    You're an idiot. A REAL supercharger draws a significant percentage off the V6 power to do what it does, let alone the I4. At PEAK efficiency an electrical unit might see 10% efficiency (and that's on a single energy transfer! you'll have many more) which means you're drawing over 10 times more power from the engine to drive an electric supercharger via alternator that a drive belt. You couldn't even power one with the 4 cylinder at all, you could drive it with the V6 but not actually gain any power form it.
    Seriously, a vacuum motor that plugs into a 110V outlet? You've got to be kidding me. You engine sucks in about as much air IDLING as that vacuum does with the filter bag full on removed. On top of that, vacuum motors don't COMPRESS air.
    Holy eff every forum has there dreamers.
    Dude seriously its not worth it...take the time and get a real supercharger please and save yourself the embarrassment
    Sent from my PC36100 using Tapatalk 2
    TGC Regular bgood12's Avatar
    07-17-2009
    554
    Maybe u are joking, but if not. Just take quick time to think about the power in kw, btu or HP that a normal supercharger adds. Convert that power into watts and you will see you will need over 10 batteries worth of power to supply the needed wattage. Therefore if car manufacturers AND formula race cars don't have them there is a reason, its not worth it. NOW you could have better time trying to make a regenerative breaking system to make the car electric I.e hybrid but the problem is that this requires more money time and research than 10 galants are worth. So you best bet Is to turbo, super, or go buy a hybrid, and or buy a lancer. Regen brakes can be done but the wiring and algorithms are complicated to turn the engine on and off and engage the electric power seamlessly while having stock driving conditions be the same.
    03-16-2010
    Maplewood, NJ
    1,290
    Not sure if this guy's is serious....
    Honestly though, do some serious research before you even attempt your crazy idea.
    13 Honda Accord EX 6MT
    I have thought about that for years. I'm thinking if u take an industrial shop vac and modify it then it would work and u could safely out 1psi for each 1hp the motor is rated for!!!
    Omg seriously go drive off of a cliff or just sell your car and buy a bicycle.
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    12-13-2010
    Brooklyn, Maryland
    4,643
    Quote Originally Posted by TruBLUE View Post
    I wouldn't trust a company with "Taco Taco" in their name to provide me with anything performance related on my car. Not gonna happen. Why's it mAd TyT3 JdM y0! in the description though? Too funny.
    Seriously, do some serious research, start with the video in Gotti's post. The answer is no. No no no no no no no no. You wanna be Ricky Bobby in here, you gotta do it the right way. It'd be cost prohibitive to properly implement an electric turbocharger on our cars, for the time, money, research and development costs spent you'd have been better off doing a turbo. If you wanna do it so you'll be the first and be different, go ahead, but be prepared to hear that "told you so" when you fail. Good luck either way though.
    There go them tags again!!!
    -Greg
    04-29-2009
    Holyoke,Massachusettes
    3,600
    I SO wanna does dis whens its done! lmao
    FreakyDeaky
    2kG 6g72/74 5 speed
Tags for this Thread
