Maybe if u have some permatex you make a light coat around inside diameter of where seal is so it won't leak as badly
Ok so this was more my fault than the devils..... I recently started having an oil leak so I decided, since it is Saturday, to take a look and find out the issue. I removed the timing belt cover to find out one of the seals on the front camshaft popped open. It was sticking out like a sore thumb so I grabbed a screw driver and tried popping it back in. My first mistake was that I didn't check the haynes manual, which I DO have! What I did was that I pushed the seal all the way in like a freaking IDIOT!!! So do me a favor and give me all the crap I deserve!!!! Anyways I turn on the engine and now I have a long streaming leak of oil dripping from the camshaft! I can't take out the seal due to lack of space! I was thinking of removing the valve cover and try to push it back out if possible. Any ideas anyone? All I have is $5 till payday Tuesday! So I have placed myself in a huge predicament! I hate myself right now please help any ideas or suggestions! I own a 3.0l stock. Thank you!
before you permatex the hell out of it, remove valve cover first so you can retrieve the seal, inspect seal, if the seal is worn replace it
G-spot I was thinking that as well. Is there a possible way of retrieving the seal that way?
try and replace seal first, your going to be disappointed when it still leaks after permatex
http://www.permatex.com/
<a href="http://s40.photobucket.com/albums/e202/duh2150/?action=view&current=crownvicbannerpart3.jpg" target="_blank"><img src="http://i40.photobucket.com/albums/e202/duh2150/crownvicbannerpart3.jpg" border="0" alt="Photobucket"></a>
Ok so I removed the valve cover and got the camshaft seal out. But problem now is that when I was moving the seal back in through the edge of the seal sort of stripped a bit. I'm still getting a little drop or two falling but nothing major at all. I'm sure its from that same seal that it is dripping oil from. Should permatex help in this situation?
It will help but only a light light light coat around the seal, it might be good if u can to get new seal and put the rtv lightly very lightly around it.
sry its just permatex sealant I think ultra grey is wat u use
Oooh ok now your speaking my language! :D awesome will do thank you guys for all your help!
