Originally Posted by
6G72gearhead
Haha, yes this thing see's 7500 regularly and doesn't gripe about it, but I know going any higher is looking for trouble.
So when you go with a 6g74 crank in a 6g75 it ill increase the rod stroke ratio and ease some issues that go along with having a small one, but will there still be any of the bearing issues you mentioned beforehand, or is that just solved in the rebuild?
The 6G72 just seems like it was built to rev, long rods, big bore, super short stroke. I'd like to see where power can be found there. However as much as I want that right now I want to win, so I'm after whatever will build good usable power.
Maybe its been found otherwise, but I don't see the n/a V6's needing more fuel flow than the stock fuel rail can support, bigger injectors yes, adjustable pressure regulator, probably, but the fuel supply won't be near what an FI engine will require.
