Another SOHC to DOHC swap question?
I have 1991 6'th G with 2.0L AWD SOHC engine. Is it possible to put in DOHC engine and keeping my AWD 5spd manual tranny? What other modifications has to be made to get it right?
I saw an add today that someone is selling whole 1991 Eclipse with DOHC 16V engine by parts!!! If he has good engine - I should consider this...
Anybody???
I was also considering sth else... What if I install DOHC engine head, valve cover and 2 DOHC cams... on original block? I know it was done, but what else has to be considered? Does the ECU has to be changed too?
i say do the swap only thing is i don't know if your tranny from the SOHC will work with DOHC.
Tranny... yes, that is a good point...
I called the guy... He said the engine is in awsome condition (it is 1992 an not 1991), i t has about 80.000 miles on it, but he already sold the tranny... He wants $700 USD for it - the price is good as far as I am conserned.
But again, anybody please - what about the tranny? :?: :?: :?:
ill take a look at my tranny and at my friends Talon TSi AWD tranny and see if there are any differences, they are both the 4g63 engine ill get it up asap!!
if i'm not mistaken the SOHC and DOHC use the same blocks.
So it should work. you may have to put a better clutch in if it
is a 5 spd
If yours is 4G63 SOHC and the new one is 4G63 DOHC the only differences are with the engine itself; you might find your gearbox has different ratios to the DOHC one but it should all line up since they're both for AWD
8) WELCOME TO MY WORLD 8)
