Thread: Replacing suspension
Showing results 1 to 3 of 3
    TGC Regular Guzm4n's Avatar
    02-02-2011
    Des Moines, IA
    736
    I might switch out my suspension to my GR-2s and S. Techs pretty soon, and I wanted to know what else should I replace? I am going to get new strut mounts and I also read that I have to cut the bump stops.
    06-16-2010
    Fort Mill, SC
    2,282
    Re: Replacing suspension
    Check end links, stuff like that. I'd say whatever needs to be done while you're in there
    Sent from my Samsung Galaxy S2 on ICS 4.0.4 via Tapatalk 2
    -Andrew
    Quote Originally Posted by DTP View Post
    What are the other stuff that might need to be addressed. My cars at 130k and I recently got new struts and springs installed as well as new cv axles on both sides. What are some things I can consider looking into to replace/check. I have lower ball joints on my list, aswell sway bar bushing for both front and back.
