Thread: Need help with starting 2000 4 cyl.
Showing results 1 to 2 of 2
    I removed the gas tank about 8 months ago to modify the rear suspension . I also removed the battery at this time. The gas tank sat empty all this time . I have installed everything back into the car now and have tried to start the car. It turns over fine but will not start. I know this is not much to go on but was hoping someone can give me some idea on getting it started. Thanks in advance.
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    Probably have the fuel pump wires disconnected
    <a href="http://s40.photobucket.com/albums/e202/duh2150/?action=view&amp;current=crownvicbannerpart3.jpg" target="_blank"><img src="http://i40.photobucket.com/albums/e202/duh2150/crownvicbannerpart3.jpg" border="0" alt="Photobucket"></a>
