Thread: GSX_TC's Galant VR4 Build thread #550/2000 (Samara)
Page 1 of 13 1234511 ... LastLast
Showing results 1 to 20 of 259
    Whats up guys, my name is Mike Valencia and this is my 91 Galant VR4 #550/2000 and this is my build on her. her name is Samara btw =)
    Body:
    New Nile Black Paint
    JDM Front Bumper
    JDM Rear Bumper
    BoostX Front Lip
    JDM Post Facelift Foglights
    JDM "evolution spec" OEM Vented Hood
    JDM H4/H1 Headlights
    JDM Prefacelift Clear Corners
    JDM Gas Tank Door
    JDM Full Time 4WD Grille
    Replica JDM side Decals
    Engine:
    Built 6-Bolt 4G63
    Balance Shaft Eliminator Kit
    Polished Crank
    Clevite 77 bearings
    Ross Racing 8-5-1 .40 over pistons
    Pauter Chromoly 4340 Billet Steel rods
    ARP headstuds
    Cometic High boost Headgasket
    3G lifters
    3 Angle Valve Job
    Ferrera Stainless Valves
    Double Springs
    Titanium Retainers
    HKS Adjustable Cam Gears
    Forced Performance FP2 272 Duration Cams
    Power Enterprise Kevlar Timing Belt
    Zaklee Corp Clear cam gear cover
    ACT Streetlite Chromoly Flywheel
    ARP Flywheel, crank and main bolts
    Ramhorn Tubular Exhaust Manifold
    Ebay 35R Turbo
    Custom 4" Exhaust Dump
    Spearco 2-216 Front Mount Intercooler
    2.5" Aluminum charge Pipes
    Throttlebodys.com rebuilt Throttle Body
    All New OEM Mitsubishi parts
    Poly Solid motor mounts
    B&M External Oil Cooler
    Hallman Pro Manual Boost Controller
    Forced Performance 4" Aluminum Intake Pipe
    4"K&N Filter
    Fuel:
    FIC 1050cc Injectors
    Walboro 255 high pressure fuel pump
    Tranny/Driveline:
    ACT 2600 Clutch
    DSM Shifter
    4 Bolt LSD Rear End
    Cooling:
    AFCO Aluminum Radiator
    Dual SPAL Fans push and puller type
    Brakes/Tires/Suspension:
    5 Lug Conversion
    Cross Drilled rear rotors
    Khumo Ecsta AST 225/40/18 ZR Ultra High Performance tires
    18X7.5 TIG 1 rims
    Full ABS delete done properly using Mitsu parts
    4WS Delete done Properly
    Eibach Sportline's Springs all round
    KYB GR2's in the Front
    AGX 10 way adjustable's in the Rear
    Ingall Adjustable rear Control Arms
    Electronics:
    DSMlink Ver 3 on Speed Density
    GM Ait, and Omni Power 4-bar map sensor
    30 Psi Boost Gauge
    Interior:
    Pretty Standard minus the Grant steering wheel
    now for the pics
    Pauter Rods, Ross Racing Pistons, ARP everything polished crank, Clevite 77 bearings
    Cometic Head gasket, 3 angle valve job, Ferrea stainless valves, double springs, titanium retainers and 3g lifters, FP2 cams, HKS cam gears, and power enterprise kevlar timing belt.
    Spearco 2-216 Front mount
    New power steering rack
    Redline fluids for the Trans, transfer case and rear diff
    ACT Streetlite flywheel and ARP flywheel bolts
    Fluidampr with ARP crank Bolt
    All new gaskets, bolts, washers, Orings etc etc
    new OEM Mitsu Clutch master and Slave and throw out bearing with braided clutch line
    new OEM Mitsu Alternator and Starter
    new OEM Mitsu belts, Walboro 255 fuel pump, OEM 0/2 sensor, thermostat, fuel filter, and spark plugs.
    DSMlink version 3, speed density parts, and HKS BOV
    STM external oil cooler kit
    new OEM lower cover, zaklee upper clear cover, and FP2 cams with my powdercoated Valve cover
    got another piece to add to the build.
    FP 4inch intake non recirculated, with massive K&N filter and a miracle reducer coupler that allows that huge intake to fit onto my evo III big 16g =)
    Coil On Plug setup, and some FIC 1050cc's
    Some more Progress pics, =)
    On the lift
    this motor got me from Cali to Ohio, then cali to AZ then Cali to TX =)
    Before
    pressure washing
    After
    about to put on the ACT streetlite, with ARP bolts
    old clutch back on, now to put it back in next.
    Ok the new Motor is finally in =)
    So clean and fresh
    New OEM Mitsu Slave going on
    stainless bolts for the oil pan
    New OEM Mitsu Starter going on
    the old motor lurking in the distance
    New OEM Mitsu Clutch master going on next
    New Fittings for the STM external oil cooler kit
    New OEM Mitsu Alternator going on now
    A bottom view of the new setup
    and the Spearco 2-216 getting mounted
    More Progress coming Soon :D
    anyways, for what its worth here are the pics i took during that all night no sleep night.
    some teaser pics of the final product, for now atleast.
    haha thanks guys
    got some more new parts in the mail, thanks to Stealthtt24, here's GSX_TC's Galant VR4 start up - YouTube a video of the start up, i love the way the FP2 Cams sounds }:D
    an AFCO radiator and Spal Fan, this fixed my overheating problem thank god
    Got a few more things to add onto her exterior =)
    JDM rear bumper came in, at first i didnt like the JDM rear bumper but i have to admit, it kinda grew on me. plus now i have a nice provision for a decent twin tip exhaust. I paid a bit more to have it shipped unfolded because i didnt want to have to deal with using a heat gun again and heating the edges back to its original form. anyways enough of my babbling here are the pics.
    Even came with all the brackets, which was pretty sweet
    Also got my Rain guards in, these flew in from BangKok! been lookin for these for a while.
    Hell yeah, my baby made it into the DSMtuners.com 2013 Calendar! She's on the cover for the month of June, sweet! =)
    http://www.cafepress.com/dsmtuners.749512205
    wow nice car my dude..
    -Danny
    Quote Originally Posted by deeznutz View Post
    Ally and her whip a day helps keep the drama away!
    oh yeah!! I rememeber following this build thread on another site. Super clean Gvr4! Good stuff on the feature
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
    02-18-2009
    NEWBURGH, NEW YORK
    486
    Sexy . Very sexy . Can't wait to see the finish product
    Nothing is nicer then a early 90's mitsu
    Samara is so sexy inside and out. Very nice.
    TGC Regular foxbrand's Avatar
    06-18-2011
    chicago suburbs, IL
    600
    this thread
    This is an awesome build! I can't wait to see the numbers she puts down, nvm it'll be a sweet ride on the streets!
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    12-13-2010
    Brooklyn, Maryland
    4,643
    Absolutely beautiful!!!
    -Greg
    I know that name of this car somewhere but wasn't sure
    Thanks guys, yeah after i get here where i want, im gonna fly out either Yusuf Begic of Flyinfevo2uning or Sam from Road Race Engineering to come and tune her. i'll be happy if she gets to the 500AWHP mark =)
    91 Galant VR4 -Samara- #550/2000
    Sick ride bro!
    Well, I finally Got my Rear Window visor from across the pond. =) took over a month to get this, and i cant wait to put it on Samara =)
    Today im dropping off my JDM rear bumper to get painted the same color as the rest of the car too, as soon as it opens i'll be there haha. this has been such a good december.
    So $375 bucks later, and the JDM rear bumper is ready and paint matched, here are the after pics. im happy. =) next i'll be putting on all this stuff together at the same time, should make for a pretty good rear end transformation.
    So i added a bit more to my register at my Second Job
    even did my Keyboard as well haha
    Well $400 bucks later and i got my NHRA Certified Moroso Battery Box (part #74051) and Moroso Battery Relocation Kit (Part#74055) and Optima Yellow Top. This will all be going in the trunk. =)
