Thread: Isaurio's Turbo Built "4G64T" Heavy pics
Page 1 of 14 1234511 ... LastLast
Showing results 1 to 20 of 269
    06-13-2008
    Bronx, NY
    2,606
    It’s been a long time waiting, collecting parts, research, DECISIONS, DECISIONS. But I took the first step and is no turning back now.
    Members to thanks for making this built possible with their help and advises.
    1.DeezNutz "Dion"
    2.Stewi "Brian"
    3.Goosey2099 "Roman"
    4.Galant2010 "Robinson"
    5. Shop S & T Auto body In the Bronx
    6. ACAMUS "Programming GURU"
    7. Other members
    Project:
    4G64 SOHC Turbo
    Short block:
    4G64 block 0.024 over
    Wiseco 1400HD Forged Pistons 87MM
    Manley H-Beam with ARP-2000 Rods
    OEM 100mm crank, micro polish, coated and balance 10K RPM by ACE Crankshaft
    ARP rods bolts
    ARP main bolts
    ACL STD main tri-metal bearings
    Clevite STD 77 Rod tri-metal bearings
    STM balance shaft elimination kit
    OEM- Water-oil pumps, timing belt, pulleys, harmonic balancer, gaskets, bolts etc.
    OEM EVO 8 oil filter housing with evo bolts *Galant bolts don’t work*
    OEM oil filter after breaking –
    2 WIX 57092 oil filter. 1st for 20 miles, 2nd for the rest 980 miles.
    OEM Evo 8 Oil Pan and oil pickup tube
    Redline assembly lube and amsoil assembly lube
    AMSOIL break in oil
    HEAD:
    OEM SOHC head cleaned, hot tank, resurface for multi-layer gasket
    COSMETIC head 87mm gasket.
    OEM new lifter
    New seals
    RPW stage 3 turbo cam, 272 "0.300" lift intake 272 exhaust "0.300" lobe centre line "112 deg" HKS turbo rally.
    RPW upgraded springs
    NGK spark plug gapped by AR Design
    EVO 8 coil packs
    MAGNECOR spark plug wires KV85 8.5mm
    Transmission:
    3G 5 speed eclipse Transmission
    Fresh rebuilt, new seals, all synchros 1-5th replaced.
    Quaife LSD *Thanks Fetal1*
    Clutch Masters 05048-HDC6 FX400 Street/Strip Stage 4 Kit 6 puck clutch
    AMSOIL Synthetic Manual Gear Lube 75W-90
    New axles
    New MOOG front wheel hubs
    Fuel System:
    Outlander mani
    6g72 diamante TB with mil.spec seals and rebuilt by "SilverTune"
    Evo 8 AMS fuel rail with pressure gauge
    Evo 8 FIC 750cc injector
    aeromotive fuel pressure regulator
    Walbro 255-HP fuel pump
    EVO 9 map sensor
    Evo 9 MAF sensor
    AN fittings
    BOOST:
    Garret 60-1 turbo stage 3 max HP 550
    UCS performance custom t3/t4 Manifold Ceramic coated black by "Detective Coating"
    UCS performance custom Down Pipe
    USC performance custom intake, fmic pipes
    TIAL F38 38mm Waste Gate 11psi spring
    HKS Super SSQV4
    3” Injen EVO 8 intake with K&N 3” air filter
    AN fittings
    Misc:
    13 row OIL cooler – 8AN
    10 row power steering oil cooler
    JM fabrications deluxe polished oil catch can -8 AN with K&N filter and level Gauge
    vibrant vacuum block
    AEM Tru-boost controller
    AEM wideband
    Prosport Oil Temp and pressure gauges
    Mishimoto evo 5-6-7 Aluminum radiator
    Mishimoto evo 5-6-7 Aluminum fan shroud
    And more that I don’t even know. LOL
    Tuning:
    TDM tuning “by ME”
    Stock 02 Galant ECU
    2.4L Big Map ROM at 300 Loads, 8500K RPM "Thanks to ACAMUS for giving a hand and time to the 2.4L big maps"
    EVO 9 MAF Tables
    2 steps
    CEL on knock
    And more.
    SOME PICS
    update from 12/15/12
    More work, more holdups from missing parts.
    update 12/21/12
    Working progress on big map. Fine tuning needs to be done.
    update 12/22/12
    SOHC Turbo
    JEEZUS! LOL *overload*
    Too much winning ^__^
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
    Your very welcome buddy I enjoy putting together this motor and can't wait to get behind the wheel and lay some rubber down ;)
    Good stuff guys! Can't wait to see it in person! I was just wondering... Is there a reason why the evo ecu is not used?
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    ^^^ yea cause its not needed!!! He's running big maps in his ecu so it recognizes boost!!!
    06-13-2008
    Bronx, NY
    2,606
    Thats right. No evo ecu need it. Boost control will bee use external with tru-boost controller. Stock rom will do the calculation for 100+ loads. The calculation responce should be faster since the ECU dont have to calculate the turbo portion tables.
    SOHC Turbo
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    nice build, how much do you have left? just a little tip though on your quaife, since you have the tranny out of the car test your axles out. people have had problems with the older versions including myself, what happens is the axles dont lock and when you fill with gear oil it all leaks out. it will look and feel
    like there locked in but if you give one a good pull and it comes out then you know you have a problem. its usully just one side.
    06-13-2008
    Bronx, NY
    2,606
    Not much left. just a few more parts like ss lines. But i need to measure when the engine is inside. Thanks for the advice, we will double check the axles.
    SOHC Turbo
    dont have to do that i already know the axels dont leak..
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    This is a great build so much $$$$$ spent in those parts lol hope its finished soon and you can enjoy it for a long time ;)
    4g64T 5spd
    Looks real good.
    Did you rebuild that throttle body? If not it's going to leak like crazy.
    12-13-2010
    Brooklyn, Maryland
    4,643
    Can't wait for the Corona meet, I wanna see this beast in person!
    Cruel Summer 2013!
    -Greg
    03-16-2010
    Maplewood, NJ
    1,290
    Good looking stuff Isaurio. Cant wait to see it in person as well.
    Dion, you need to eat more lmao
    13 Honda Accord EX 6MT
    No silvertune it hasn't been rebuilt it actually a pretty clean t/b once we get it running ill double check it under boost.
    @ Carl kiss my skinny white ass lmao dude I'm trying to but my metabolism won't let me!!!
    06-13-2008
    Bronx, NY
    2,606
    ^^lol
    Tb is not rebuilt like dion said. But i wont bee on hi boost for the first 1000 miles. So it should be all good. I will check after the break-in.
    SOHC Turbo
    What an awesome looking build that is.
    You'll want to, I haven't come across one that hasn't leaked on anything above atmospheric, I've lost count on how many I've done now. If you find yourself needing any assistance with it though let me know. Good luck! I expect you'll make some pretty good output.
    Mil-spec shaft seals ftmfw! When you're ready to turn the boost up they will come in handy. Looks good though. Can't wait to see what it puts down.
    TGC Regular foxbrand's Avatar
    06-18-2011
    chicago suburbs, IL
    600
    Awesome stuff, so much so tapatalk is refusing to load images
    To the laptop!
    *old-school Batman transition*
    Just because something is old, doesn't mean you throw it away
    Geordi La Forge
    Looks like its gonna be fun when it hits the street, nicely done
