Thread: Isaurio's Turbo Built "4G64T" Heavy pics
Page 10 of 14 FirstFirst ... 67891011121314 LastLast
Showing results 181 to 200 of 269
  1. #181
    Good work. Did you install oil squiter in the block or you don't need it because of forge piston? I'm getting close to starting my turbo project.
  2. #182
    06-13-2008
    Bronx, NY
    2,606
    Not need it for forge internals. Internal is all forged
    SOHC Turbo
  3. #183
    06-13-2008
    Bronx, NY
    2,606
    Okey guys. Round 2
    Pull out the engine again and doubled checked oil pump. Balance shaft bearings. Everything was by the book.
    Now i had a evo 9 oil housing. Not much of a different between the evo 8 it just have the extra 1/4 npt for the oil pressure. I think also the pressure springs are different.
    Put the evo 8 housing. Put everything back together and so far after 10 min of running no oil light. I will check pressure with mechanical gauge.
    Now i have a supper lean condition need to to check the problem
    Magnetic plug
    SOHC Turbo
  4. #184
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    that sucks you had to pull the motor, you know i never seen anyone use that port on the filter housing bracket for anything so i dont know if that had anything to do with it. the 1/4" bspt ports are the ones always used for oil feeds or sensors.
    you didnt mentioned if you oil primed your motor before you did the timing belt but its a good way to test the oil pump beforoe you drop it in. when brian built my motor we did just that and got no oil surfacing to the head, we pulled the oil pump cover off and opened the actual oil pump gear cover thats on the inside and packed it with vasaline. put it all back together, tried again and bam oil started pouring out the top of the head. the quack machinists that built the rotating assembly warned me this might happen with a new oil pump cover and that its sort of a hit and miss thing and told me exactly what do if it does happen. next oil pump cover i use i will be sure to pack the gears with vasaline before i install it.
    another thing most guys change the oil thermostat to a tomei, you get it from extreme psi. its the funny looking brass thing next to where you had your oil feed plumbed into.
    what turbo are you running ??
  5. #185
    06-13-2008
    Bronx, NY
    2,606
    ^ yeah. We did not post prime the oil pump. We crank the engine a few times without the crank sensor or the fuel pump. So oil could flow. I guess it was an issue with the evo 9 oil housing. Not too sure. I also prime the oil cooler so it wont take long to fill up with oil. I think that did the trick. I not to sure i will double check pressure with mechanical gauge to see where she at. Oil is coming up the head since i open the oil cap and oil was coming up.
    Also i notice. With the mixture of the amsoil breaking oil and the and the engine assembly lube oil got a lil thick. So is twice as hard to flow around the cooler and lines. Making lose pressure
    Is a garret 60-1 turbo. I got it to 12psi and 5psi spring rate on tru boost control. Just for break in.
    SOHC Turbo
  6. #186
    08-26-2007
    1,148
    thats another thing, you dont need the oil cooler hooked up for start up. actually its better you dont so you dont contaminate the cooler and lines with assembly lube and and metal shaving from moving parts that are getting to know each other. thats how i did mine, ran it for about 15min let it heat cycle, shut it down drained the oil using a paper towel to sift any shavings out of the oil (really just out of curiousity you dont have to do that part). then re-torque the head studs, filled with cheap penzoil not the baller stuff you got and then ran it for 1k before th dyno.
    cleaning the oil cooler and lines out really good would be something you might want to do, maybe even the the turbo feed line and maybe blow some air through the turbo oil passage. im so petro though when it comes to things like this that i would replace the cooler right off the bat, my b&m cooler is only $80 so to me i see it as disposable lol.
  7. #187
    06-13-2008
    Bronx, NY
    2,606
    Lol. Good ideal. I wi do that. Thanks
    SOHC Turbo
  8. #188
    06-13-2008
    Bronx, NY
    2,606
    So. here is the 2.4L stock Crank fueling. This is great to adjust if you go with bigger injectors. That way PCM/ECU dont OD the fuel at crank. It will help with cold start crank with bigger injectors.
    Got this to leave the stock oil pressure switch and add my prosport evo oil pressure behind the block.
    SOHC Turbo
  9. #189
    Nice!
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  10. #190
    yep that cranking ipw was a pain in the ass to work around when my injector size went up. tuned it out through the maf so I wouldnt be flooding the cylinders when I fired up. good stuff so far man
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  11. #191
    06-13-2008
    Bronx, NY
    2,606
    He is a second start up. Got mechanical gauge and she is reading 60-90 psi behind the block around 1000-1500 rpm
    Thats a good sing
    SOHC Turbo
  12. #192
    nice strong idle after the car caught itself!
    gotta fix the link though. I just copied the link and opened it in a new tab in my browser and it worked.
  13. #193
    06-13-2008
    Bronx, NY
    2,606
    Um i think is because is private. I will fix it.
    Yeah the 1200cc pte injectors are a pain to tune and get it to stay stable. My o2 is maxing out at 25% rich at idle.
    I will jump to the 650cc and tune that until i get it to a pro-tuner and fix that 1200cc
    But men she sounds strong.
    SOHC Turbo
  14. #194
    12-13-2010
    Brooklyn, Maryland
    4,643
    Does she ever! Good stuff bro!
    -Greg
  15. #195
    Trying to fix the link:
    http://vid726.photobucket.com/albums...ps51d7c62f.mp4
    Thats a good sing
  16. #196
    She sounds real good man!
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  17. #197
    06-13-2008
    Bronx, NY
    2,606
    ^ thanks bro. She is not even stable. Open headers lol
    SOHC Turbo
  18. #198
    06-13-2008
    Bronx, NY
    2,606
    After patching the leaks and some more injector tuning. Got her running a little longer. Better idle
    Crazy loads at low rpm. The 2.4 87mm could really move some air
    SOHC Turbo
  19. #199
    How come there's so many empty spaces? Shouldn't they be all filled with values?
  20. #200
    06-13-2008
    Bronx, NY
    2,606
    Not really it depends on the load and rpm is reading. When u do 3rd gear pull it only show the cell the ecu is hitting skip others. Also it depends how long in average it stays active in a given cell.
    My cells only shows crank and idle.
    SOHC Turbo
