Thread: Isaurio's Turbo Built "4G64T" Heavy pics
Page 11 of 14 FirstFirst ... 7891011121314 LastLast
Showing results 201 to 220 of 269
  1. #201
    06-13-2008
    Bronx, NY
    2,606
    videos links fixed
    SOHC Turbo
  2. #202
    Very nice
  3. #203
    Is this the evo ecu?
  4. #204
    06-13-2008
    Bronx, NY
    2,606
    no. all stock pcm
    SOHC Turbo
  5. #205
    ^^^acually it's a stock modified PCM... Because no other stock PCM has what yours has ;)
  6. #206
    06-13-2008
    Bronx, NY
    2,606
    ^^^^ 100% true that. forgot to add that. Thanks buddy.
    SOHC Turbo
  7. #207
    After patching the leaks and some more injector tuning. Got her running a little longer. Better idle
    Crazy loads at low rpm. The 2.4 87mm could really move some air
    Damn she sounds good and idle seems to be fixed!
    The table you have pulled up, is that in evoscan?
    Also do you just delete the tables in evoscan to NOT log them? I see yours looked like a list of 15-20 instead of my usual 40-50 lol.
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  8. #208
    06-13-2008
    Bronx, NY
    2,606
    Thats evoscan log.
    Evo scan long on live tables usual picks up loads and rpm the pcm hits constant this speed up data log. If you log evey bit it becomes slow and big data
    The idle pcm trying really hard to make up for the boost leak. But she need the injector dial in 100%
    SOHC Turbo
  9. #209
    niiiiiice strong idle. lol wtf rpm are you seeing 100% load at? haha
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  10. #210
    06-13-2008
    Bronx, NY
    2,606
    ^^^LOL thats at 2000 RPM when i look at my tables.
    SOHC Turbo
  11. #211
    Bro wth?! Haha I am so waiting to see a pull on a dyno or a virtual dyno graph. :)
  12. #212
    Got a question on your head gasket. Are using the 4g64 or 4g63 87mm head gasket?
  13. #213
    06-13-2008
    Bronx, NY
    2,606
    63 87mm
    SOHC Turbo
  14. #214
    06-13-2008
    Bronx, NY
    2,606
    Ok guys. With a few research and some calculation. I got a base data for the FIC injectors. I compare the 2.0 evos scaling and latency for FIC 750 and 720 and added 20% more to compensate for the extra displacement. It should bring me close on my fuel trims
    excel preview that i made for the 2.4L 87mm. This is for my setup.
    SOHC Turbo
  15. #215
    That is a very nice layout! You are correct on the 20% number thats for sure
  16. #216
    Nice! I used your excel layout and the 3.5L compared to the evo.
    I did 3.5L / 6 = .583 * 4cyl = 2.333L ~17% Would this be correct? lol!
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  17. #217
    06-13-2008
    Bronx, NY
    2,606
    Yes. Now that should give you a base. U need to reduce x=% fuel.
    Use gts maf scaling and smoothing
    And bump the injector scaling by x=% of the stock evo. Increasing it should reduce fuel
    * i notice your calculation is a little much. It should be less percentage due to the limit of the 560cc and ecuflash.
    SOHC Turbo
  18. #218
    Very nice, thanks =)
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  19. #219
    06-13-2008
    Bronx, NY
    2,606
    Keith i made some raw calculation and came up with a great formula for injector scaling. This should help you. Like i said base to get it start it. Then fine tune the after that. Check this out
    We have a fuel pressure of 43.5PSI with vacuum it goes down to 38-40 depends of your CR. SO:
    38psi lets say for most application. Mine is at 40psi
    38psi/43.5psi*100 = 87.35% so the rest of 12.65% this is what you do
    You have evos 560cc injectors your calculation will be
    560cc-12.65% = 490cc in ecuflash calculation is 513cc Final tune by Mitsubishi *for EVOS*.
    So now. Your bore is 90mm evos is 85mm. 90-85= 5% "mine doubles triples because of the stroke" evo is 88mm compare to your 85.8mm" making the 4g64 100mm stroke. Making it 15% 20% more fuel.
    So now we have an % remember this is ECU flash injector scaling fueling. Evo will flow more air per cylinder because of the stroke of 88mm that is why if you put evo injectors to the v6, injectors will flow more fuel making your AFR rich because of the stroke with 513cc scaling.
    Final calculation. 490cc+5% 514.5=515cc, this is a base depends on the head flow and mods. In ECU flash there are constant values that default by the formula and Mitsubishi code formula.
    Your base 515cc on ECUflash will be 532cc evos is 513cc base on the 490cc calc
    if you see ecuslash scaling and you use the [] you will see 496cc making too rich default evos mitsu made it 513cc after their final tune "still made them rich to save knock", yours will be 532cc after your 515cc calculation we made.
    Hope it helps. you need to leave it at 532cc as base it should get you close to +-3%. I would use the GTS maf scaling and smoothing and work for last after you get your trims down to -+3% or so with scaling and letancy.
    532cc scaling *increase will make you leaner*
    -5% from latency of stock evo *decrease latency will make you leaner*
    SOHC Turbo
  20. #220
    Very nice man! I'll save this to my records =)
    My base fuel pressure is 48lbs without vacuum and it goes to 42 with. I should turn it to 40 then and start tuning from that. Thanks bro, hopefully I can give her another go this weekend lol. I about finished my wire tuck and have to figure out another way for my intake to run before I try again.
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
