Thread: Isaurio's Turbo Built "4G64T" Heavy pics
Page 13 of 14 FirstFirst ... 391011121314 LastLast
Showing results 241 to 260 of 269
  1. #241
    02-17-2011
    i live in sunny florida
    1,240
    Good looking out bro. Just tying to understand what you guys are doing and I completly understand the situation,
    Sent from my PG86100 using Tapatalk 2
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
  2. #242
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by finald8ta View Post
    They doing it because is a great add-on but dont know the problem. Gasket cover the hole but dont seal it 100%. They dont notice big change on NA because the computer is trying to make up for it. But you need a spacer for the v6 tb or go with evo or outlander.
    SOHC Turbo
  3. #243
    08-13-2008
    Waterbury, CT
    3,331
    15 vacuum is good with 272 cams. more duration, means longer over lap which means less vacuum. I have 272 duration stroker cams and im looking to be around the 13-16 vacumm range, with 280 cams its around 10 vacuum. I am sure that seal wasnt helping and could be a nice boost leak tho. good info for 8G people.
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
  4. #244
    06-13-2008
    Bronx, NY
    2,606
    Ok. After a few hr of tuning the injectors 750cc. I got the G to fire right up even when engine is warm. Adjusted the IPW on crank. and adjusted scaling. She holds idle but for some odd reason she is showing "o2 and wideband that is lean" 24.8% on the o2 feedback and 12.5% on the low trims. Got a CEL of lean of curse after the 12.5 lean trims.
    I'm going crazy trying to find the dam issue. Exhaust leak or another boost leak? The scaling and latency are very close since she is staring and holding idle. But stupid o2 is messing everything up.
    PS. on open loop she is fine cold start. AFR are money at 14.7-15 like the map shows. but when it goes to open look o2 reads lean. making the ECU add extra fuel and mess everything up. WTF.
    SOHC Turbo
  5. #245
  6. #246
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by evo_powered_galant View Post
    how is the tuning going?
    I got the injector scaling closed. Now is at 5-10% not 24% anymore
    It dont turn off on me. Tomm will put my front seat and take her for a ride. ^_^
    More tuning needs to be done. Latency is next
    SOHC Turbo
  7. #247
    and if i read right.. you are using a stock ecu right? wouldn't a evo ecu be better as far as tuning?
  8. #248
    ^^^Lmao noobs smh
  9. #249
    lol..... some people's children.
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  10. #250
    06-13-2008
    Bronx, NY
    2,606
    Lets tuning and breaking begging. She was tested a few times on the road and she is healthy. Still needs to tune injectors better. The 272 dont help a lot of overlap. But getting there
    Exhaust 3" is done. She is a lil low now. I think i need a bigger and longer resonator
    Here is a small clip with the exhaust. Mean idle.
    SOHC Turbo
  11. #251
    That sound is absolutely to die for IMHO. Tuning the best is the fun part as you get to feel more power pull after pull!
  12. #252
    Problem for him is I've been doing all the driving so far hahaha!!!!
  13. #253
  14. #254
    06-13-2008
    Bronx, NY
    2,606
    Car runs. Still waiting for radiator. And do interior
    SOHC Turbo
  15. #255
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by deeznutz View Post
    WHAT! someone needs to monitor your ass. LOL
    You know you like driving her. Don't front.
    SOHC Turbo
  16. #256
    07-02-2011
    South Florida, by the beach
    1,076
    Updates? videos?
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
  17. #257
    06-13-2008
    Bronx, NY
    2,606
    Jaja. Did not know this existed still. Will try to revived and update my long ass money pit project. Fyi i still have her.
    SOHC Turbo
  18. #258
    06-13-2008
    Bronx, NY
    2,606
    Mod 2014
    SOHC Turbo
  19. #259
    06-13-2008
    Bronx, NY
    2,606
    SOHC Turbo
  20. #260
    06-13-2008
    Bronx, NY
    2,606
    Egr delete
    c2e4b7638429b6fa5e39ebd943aa90f4.jpg[/IMG]
    SOHC Turbo
