Thread: Isaurio's Turbo Built "4G64T" Heavy pics
Page 4 of 14 FirstFirst 12345678 ... LastLast
Showing results 61 to 80 of 269
  1. #61
    Hey bud, where did you get these silicone coated lines? Link?
    Thanks
  2. #62
    06-13-2008
    Bronx, NY
    2,606
    Thanks
    Sure. I get most of the lines and fittings from:
    http://www.siliconeintakes.com/
    SOHC Turbo
  3. #63
    06-13-2008
    Bronx, NY
    2,606
    Lil update guys:
    0 gauge power and negative for bat relocation to trunk
    -16 welds bung for radiator.
    Installed radiator fan. Push and pull
    And new location for engine oil cooler.
    New vibrant 3" muffler and resonator
    Doing some ss line for oil catch can
    Pvc valve deleted crank gas will be vented with vented oil catch can
    SOHC Turbo
  4. #64
    damn looking good
  5. #65
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by specter6633 View Post
    damn looking good
    Thanks bro.
    SOHC Turbo
  6. #66
    02-17-2011
    i live in sunny florida
    1,240
    im abit confused about your catch can setup.
    dont you want it to have a suckion so it ill pull all the air/oil out of the VC/crankcase?
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
  7. #67
    08-13-2008
    Waterbury, CT
    3,331
    Quote Originally Posted by finald8ta View Post
    deleting the PCV can cause crank case pressure issues, in DSMs and evos usually we weld 2 AN fitting onto the valve cover and run those to the catch can and leave the PCV alone
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
  8. #68
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Everything looks great Isaurio, I would really like to hear that exhaust setup,
    You'll have to make a spacer for the TB, and buy some evo Mil spec seals for the TB, you'll thank me when you do a boost leak test
    4g64T 5spd
  9. #69
    Build is looking good homie! Hey what application did you get your aluminum radiator for?
    I ran my catch can the same way except I kept the PCV.
    Jigz-TGCIL Sosick Motorsports
  10. #70
    06-13-2008
    Bronx, NY
    2,606
    Thanks guys.
    PVC valve. A lot of you have it confuse. The valve it self is use just for emission and to keep oil from going in to the intake mani. I know u need some type of vacuum on idle to get the crankcase gases out. But since is no valve it should be free flowing out. On boost u needs as much opening and flow to release the pressure of the crank. Is a -8 line it should be good. Of anything i change the setup.
    SOHC Turbo
  11. #71
    06-13-2008
    Bronx, NY
    2,606
    You do you mean about application on the radiator?
    SOHC Turbo
  12. #72
    Like is it for an evo or the 3G?
  13. #73
    Looks good, what TB is that?
  14. #74
    You need a PCV valve so pressure in the manifold doesn't push back into the crank case. If you don't have a check valve between a boosted passage and your crank case you will volcano oil all over that pretty engine bay.
  15. #75
    06-13-2008
    Bronx, NY
    2,606
    Evo 5-6-7 mishimoto radiator.
    SOHC Turbo
  16. #76
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by GOOSEY2099 View Post
    Thanks bro. Thats the diamante tb.
    SOHC Turbo
  17. #77
    did you change the shaft seals in that??
  18. #78
    06-13-2008
    Bronx, NY
    2,606
    Both port on the valve is going to a oil catch can vented with filter. Dont see how it pressure will built on the can.
    SOHC Turbo
  19. #79
    06-13-2008
    Bronx, NY
    2,606
    No i have not. Not sure what seals fits on the 74. I just want to break in engine for the first 1k miles. Im not going to full boost on break in. Just normal driving not to crazy.
    SOHC Turbo
  20. #80
    I wasn't saying yours was, I didn't actually look at how you set yours up just yet. It was just a general comment. Running the can to vent is alright so long as you have valves in the lines so it can't pull unmetered air through the can.
    There are no aftermarket seals for the 74 tb, they're smaller than the other Mitsubishi stuff that does have aftermarket support. You can mod the housings to fit the aftermarket seals though. I rebuild throttle bodies with them all the time.
