Thread: Isaurio's Turbo Built "4G64T" Heavy pics
Page 5 of 14 FirstFirst 123456789 ... LastLast
Showing results 81 to 100 of 269
  1. #81
    yeah you need good seals cause original crap leaks like a used up whore in the am.
  2. #82
    06-13-2008
    Bronx, NY
    2,606
    Yeah. I was thinking about that. I will do a leak test and see how much it leaks out. But i will take ur advice to find a way to rebuilt it.
    About the maf is very minimal getting un-meter air thru the can. I have 1200cc injectors im sure i will run on the rich side, if it gets air not calculated by the maf, extravair is good since it will lean out the mixture a bit. Nothing a tune and some logs would fix.
    Doing this setup
    1. to keep the oil and hot gases going back or getting mix on the mani avoiding a lot of pro later.
    2. By deleting the pvc "restricted oem pvc" and have a flowing track it will flow out the gases better from the crank specially with psi above 20 and hot cam. I could always change it later.
    SOHC Turbo
  3. #83
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    As I said like 15 comments before you need a spacer for that TB/IM combo and Mil Spec seals work on the 74 tb its a little tight of a fit but just need to press them in ;)
    4g64T 5spd
  4. #84
    06-13-2008
    Bronx, NY
    2,606
    ^why spacers? I used the tb on my stock setup with no pro.
    SOHC Turbo
  5. #85
    You will find that being boosted is a very different story, you don't get away with anything. If stuff isn't sealed up TIGHT you WILL leak and leak always. Tuning around it is often possible, but you just lose power and put more wear on the setup and end up with a filthy engine bay.
  6. #86
    06-13-2008
    Bronx, NY
    2,606
    ^thanks. Yeah i understand. Until i get some boost and see what i need to re-adjust i cant adjust now.
    SOHC Turbo
  7. #87
    Fix things that a guaranteed to leak now... That shit ain't a joke
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  8. #88
    06-13-2008
    Bronx, NY
    2,606
    ^thanks. Like i said need to start the car first. And sit the rings. This tb will hold just fine until the break in. Ones i get it running i take the time to get better seals for the tb. Right now im behind dont have the time to patch or fix the tb. I will do a boost test leak and see how much it will hold
    SOHC Turbo
  9. #89
    Before you even attempt starting the car I would highly recommend putting a BLT on the turbo and pumping it up 35 psi. Track down every single leak before you start. Makes like a million times easier.
  10. #90
    06-13-2008
    Bronx, NY
    2,606
    Yeah bro. I have the leak test tools to do it ones i get everything in place. Also for the AN Fittings.
    SOHC Turbo
  11. #91
    05-03-2009
    1,465
    Take your time bro but w/o a spacer, adding material or rewelding a new flange you won't hold 5psi:
    This is the problem with this TB/IM and there's no gasket that can seal that:
    This was my fix:
    Evo Mil Spec TB shaft seals on 74 TB (I didn't bore anything just pressed them in):
    Hope this help ;)
    4g64T 5spd
  12. #92
    06-13-2008
    Bronx, NY
    2,606
    Cool. Where did u get the spacer at? U need longer bolts?
    SOHC Turbo
  13. #93
    05-03-2009
    1,465
    Spacer was made by my dad from a piece of aluminum used the 74 gasket as a guide and left some extra material at the problematic areas, gaskets are made out of a thick gasket paper and covered with copper spray a gasket, the length of the bolts depends on the thickness of your spacer as you can see the ones I got are too long but they get the job done.
    4g64T 5spd
  14. #94
    06-13-2008
    Bronx, NY
    2,606
    Ok guys more updates:
    Mounted front oil cooler.
    Mishimoto power stering reserv
    Made and installed -16 AN radiator hose
    1.Dion *deeznuts* soldering and wire tuck evo injectors plugs and evo oem resistor box.
    2.finished the fpr return line.
    SOHC Turbo
  15. #95
    noice! those are some interesting coil packs and plug wires
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  16. #96
    02-17-2011
    i live in sunny florida
    1,240
    looking sharp bro, when do you expect to be done?
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
  17. #97
    06-13-2008
    Bronx, NY
    2,606
    Umm not sure. Another month or so.
    SOHC Turbo
  18. #98
    04-10-2005
    NYC
    3,695
    nice bro, looks good. i havent checked on this in a while. looks like your almost there. cant wait for the start up
  19. #99
    06-13-2008
    Bronx, NY
    2,606
    Thanks bro. Almost there. Just a few more electrical things. Test leak the AN fittings. Test leak all intake pipes. Fill her up with fluids and crank crank. Lol.
    Hows the eclipse. No dyno. I still need a ride on it.
    SOHC Turbo
  20. #100
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by Ivory8g View Post
    Thanks. Evo coil packs. Roman told me you get better performance than the stock g. Magnecor race ignition wires.
    SOHC Turbo
