Thread: Isaurio's Turbo Built "4G64T" Heavy pics
Page 6 of 14 FirstFirst ... 2345678910 ... LastLast
Showing results 101 to 120 of 269
  1. #101
    02-17-2011
    i live in sunny florida
    1,240
    n
    Lil update. Finished up doing the line for the turbo oil cooler and feed line. Black ss line with silicon cover for extra protection. Also some fuel ss line where made.
    can you explain witch line is what?
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
  2. #102
    Thanks. Evo coil packs. Roman told me you get better performance than the stock g. Magnecor race ignition wires.
    oh gotcha. yeah the evo ignition system does support a pretty high hp. good stuff
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  3. #103
    06-13-2008
    Bronx, NY
    2,606
    More updates.
    I was going crazy for my maf turbo intake setup could not find something to get in to the right place. After doing some searching I got this evo 8 injen intake i have to say it looks oem to me. Perfect fit. Did some TLC to the evo 9 maf and injen maf adapter. Looks new now.
    SOHC Turbo
  4. #104
    02-17-2011
    1,240
    looks goods,
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
  5. #105
    Whatever... That looks amazing!
  6. #106
    06-13-2008
    Bronx, NY
    2,606
    Thanks guys.
    SOHC Turbo
  7. #107
    Relocate that sender... trust me
  8. #108
    06-13-2008
    Bronx, NY
    2,606
    What sender?
    SOHC Turbo
  9. #109
    hes talking about the oil pressure sender for the gauge.
    Looks great man. nice progress!
  10. #110
    06-13-2008
    Bronx, NY
    2,606
    ^ the g is on a lift. The coils is a max extend since is not on the ground. U have 3 inch clearance at max. When is on the ground it has a 10 inch clearance. Is all good is pic playing eye game.
    Ivory thanks.
    SOHC Turbo
  11. #111
    06-13-2008
    Bronx, NY
    2,606
    Update:
    Got some exhaust v-bands
    Custom made my radiator AN hose. This will fit the SOHC with evo 456 mishimoto radiator
    My bro DION came thru with his welds relocate bottom mount points for radiator to fit stock location.
    SOHC Turbo
  12. #112
    Looks good.. Get it on the road already!!
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  13. #113
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by GOOSEY2099 View Post
    Im trying here. Lol
    SOHC Turbo
  14. #114
    06-13-2008
    Bronx, NY
    2,606
    Custom down pipe 90% done. All i need is high temp paint and heat wrap. Had good result with my last wrapped heaters.
    Heavy duty 3" thick industrial flex pipe took 4 blades to cut the bitch. Thanks Dion for the item.
    Welded wideband bung.
    SOHC Turbo
  15. #115
    Gotta use bi-metal blades and a dab of engine oil on the teeth.
  16. #116
    06-13-2008
    Bronx, NY
    2,606
    Yeah. That flexpipe is a beast. I did not have time to get fancy. The muffler shop did the work.
    SOHC Turbo
  17. #117
    Perhaps it's been mentioned, but what are your goals? Times, numbers, anything you'd like to see?
  18. #118
    damn isaurio its looking reeally good.
  19. #119
    He mentioned once, he wants to see what he can get out of the 4g64, that was all.
    Sent from my Samsung Galaxy Note 2 using Tapatalk 2
  20. #120
    08-18-2004
    Charlotte, NC
    1,029
    Im trying here. Lol
    I second that..
    1994 GS FYI
    DSM/CSM Manuals
