Thread: Isaurio's Turbo Built "4G64T" Heavy pics
Page 7 of 14 FirstFirst ... 34567891011 ... LastLast
Showing results 121 to 140 of 269
  1. #121
    06-13-2008
    Bronx, NY
    2,606
    Perhaps it's been mentioned, but what are your goals? Times, numbers, anything you'd like to see?
    I mean the 4g64 block is fully built could handle about 700hp. I want to see how much the SOHC could hold.
    I mean im not going for crazy numbers. I could get easy 400-450whp on this setup.
    The intake valves and trani is going to hold me back but im not worry.
    SOHC Turbo
  2. #122
    06-13-2008
    Bronx, NY
    2,606
    More updates:
    Upgraded new ss clutch line
    Added vibrant vacuum block. Fpr and break booster are connected. Need bov and boost control to be connected
    Mounted power steering cooler
    Radom pics. The intercooler with all pipes are 90% set, all i need is to re-enforce the sides with steal brackets and is money.
    SOHC Turbo
  3. #123
    why do you need a ps cooler again???
  4. #124
    ^^^Cause he don't friggin listen!!!! And that cooler is waaaaaayyyyy tooooo big
  5. #125
    06-13-2008
    Bronx, NY
    2,606
    Front oem cooler is gone. Why not upgrade it.
    Im using power steering it gets super hot. I mean g is going to be a daily for a while.
    SOHC Turbo
  6. #126
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by deeznutz View Post
    It will come in handy when i take it to a circuit track.
    SOHC Turbo
  7. #127
    MMMM no it wont... in fact it will probably never cool down to begin with since there is no airflow there... Useless in my opinion, just something else that can leak.
  8. #128
    06-13-2008
    Bronx, NY
    2,606
    Is by the foglight some air will flow. is better than nothing.
    I have a AN leak test kit -3 to -16 i will make sure all my lines are leak proof before i put any fluids
    SOHC Turbo
  9. #129
    06-13-2008
    Bronx, NY
    2,606
    AN test kit
    SOHC Turbo
  10. #130
    That stupid cooler was more effort installing than its worth! Sorry my friend but we don't see eye to eye on that one..
  11. #131
    06-13-2008
    Bronx, NY
    2,606
    I know. But i paid for it and not spending money on another one that u still have to find a place for it. Any custom takes work and time.
    SOHC Turbo
  12. #132
    11-29-2009
    Chadds Ford, PA
    2,768
    Use it as a oil cooler instead?
  13. #133
    06-13-2008
    Bronx, NY
    2,606
    Look at my previews pic i have a oil cooler already. Is behind the intercooler
    SOHC Turbo
  14. #134
    the PS cooler is already installed, no need to get on his case about it. cars coming along great, im excited to see her up and running again!
  15. #135
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by kylecanthurdle View Post
    Thanks. Hope is up and running soon.
    SOHC Turbo
  16. #136
    Everything is looking great! I'm so anxious to hear that first startup! we all know you are :)
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  17. #137
    Ok ok fuck it.... Let's go finish it already.. I wana hear it run
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  18. #138
    06-13-2008
    Bronx, NY
    2,606
    ^ lol. Thanks for the pump bro. All it needs is to run the batt to the trunk install the gauges. All fluids.
    Order more dam fittings. Finally i got the right thread for the outlander mani break booster vacuum. This will go from mani to vacuum block.
    SOHC Turbo
  19. #139
    damn isaurio we gonna have our first meet when you done. btw wheres ur garage i need ur expertise one of these weekeneds
  20. #140
    06-13-2008
    Bronx, NY
    2,606
    Is the shop im working on. Is about your car. Send me a pm.
    SOHC Turbo
