Thread: Best way to tie down a sub enclosure
Showing results 1 to 8 of 8
    New Member Neo8G's Avatar
    04-28-2012
    Grand Ridge, IL
    66
    So guys I'm having a problem with my sub enclosure in my trunk moving around. I've tried to tie it down many time but to no avail. SO who to you guys tie it down?
    L brackets, bolt it to the trunk of the floor, self tapping screws FTW
    04-28-2012
    Grand Ridge, IL
    66
    I do want to remove it when I go to the strip. =P
    Re: Best way to tie down a sub enclosure
    Bring a screwdriver
    Sent from Tapatalk 2 using my Rooted DROID BIONIC on Android ICS
    Bronx NYC (reppin)
    3,489
    get a L bracket and attach on end to the box. Now look in the trunk by the deck speakers and you should see a lil flared hole in the center. Its threaded all the way and fits a 12MM. If you need i can take a pic in the morning.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    Hey once you get it secured I would like to see a picture of what you did
    12-13-2010
    Brooklyn, Maryland
    4,643
    Bigger box. Mines stays put, it's backed up all the way to the seats and just barely fits under the deck. Never moves.
    -Greg
    here is something super simple..
    Velcro round tabs.
    assuming your sub box is carpeted you get 4 tabs, make sure you stick two hook tabs together, then place on one corner of the bottom of the sub box. do this for all four corners.
    then place sub where you want it.. it will pretty much stay still unless you roll your car lol.
    reason I suggest round tabs is. you can still move your sub box around with SOME ease. if you use two strips it will really want to stay planted.
