Thread: Wheel Adapters
Showing results 1 to 6 of 6
    Wheel Adapters
    I need wheel adapters for 4x114.3 to 5x114.3. Does anyone know where I can find relatively cheap ones? And what site or if ebay might be a good route?
    12-13-2010
    Brooklyn, Maryland
    4,643
    Most people will probably tell you to grab some hubs from a 5-lug 2G and swap it out that way, as it's safer and doesn't change your wheels offset. However, if you must use a spacer, see what http://www.motorsport-tech.com/ can do for you. Hope this helps!
    -Greg
    08-13-2008
    Waterbury, CT
    3,331
    Honestly adapters are a bad idea. At the cheapest I would get used 2g FWD hub assemblies front and rear and drill your rotors to accept 5 lug or get used rotors. Personally I would go all new everything but you decide what you want. I just prefer dependability and not trusting a small piece of steel
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    That's the best idea . Galant tuners can give you . So take it
    Alright thanks for the replies guys. I'll look into getting the hubs then.
