Thread: Need help with repair of 7G dash. Need help ASAP!
Showing results 1 to 7 of 7
    New Member
    02-09-2007
    Redlands, CA
    68
    Icon4 Need help with repair of 7G dash. Need help ASAP!
    The top of my dash around the defroster vents has curled and cracked due to lot damage at a body shop. They refuse to admit fault, so I'm trying to find a solution that would work on my 97 ES (7G). Replacing the dash would cost $$$ and be a major headache.
    Someone has got to have found a fix for this by now!
    Your help is greatly appreciated!
    P.S. I also need a referral to a good audio tech in So Cal. I replaced my stock radio with a Kenwood system but now I get all kinds of random issues (static, humm, electrical noise from the defroster/ AC/ revving the engine.
    Thanks again!
    I'm getting a dash cover... mines did same its just from the sun..... u can sue but idk if u will win....
    New Member
    02-09-2007
    Redlands, CA
    68
    The cracks have curled up and a dash cover would not lie flat. Plus, from what I've seen those covers never stay in place. I thought about doing the cover once BUT I've never seen one that looked good. They all look like carpet remnants.
    I did see one material that might work but I don't know the correct term for it or where I could get it. It is a liquified polymer that is self-leveling and dries to the consistency of vinyl. According to Mitsubishi, there is a hard shelf under the vinyl which could support this material if I could find it. So, if anyone reads this and knows what I've talking about then speak up.
    Thanks
    Dasd, are you using a connector or did you hard wire them?
    New Member
    02-09-2007
    Redlands, CA
    68
    Texasryan,
    If you're talking about using a cover, the answer is neither. Like I said, all covers I've seen look terrible and just become dust catchers. If you know of a dash solution, I'm down.
    I meant the Radio not the Dash Cover. lol....
