Thread: 4g64 dohc evo tps ?'s
Showing results 1 to 4 of 4
    ok guys so car is almost done got everything hooked up tried to start the car at first would not turn over and found out not enough fuel. Must have gotten a bad pump it is a 255lph. Then i got the idea to clamp off my return line and the car ran. Idles real ruff and have just now noticed that I need to rewire the tps on the evo tb. Here's what im wondering had to replace the battery cause it was fubar. new battery in car cranks, ran for maybe 5 sec died out wont restart. I also have the tactrix cable but no lap top to read the cel for info so just kind of wondering whats up.
    I'm not an expert to answer your question but for sure someone here will help you. I'm thinking to do the DOHC head so I would love to see this in person so I can get some Ideas on how to. Good Luck.
    TURBO= in the making.......
    you used the evo head or the kia head?
    Doesn't matter it refers to evo tb and tips. However not to be a dick its the KIA head.
