NEWBIE
leds in gauge cluster problem
ok so I installed some leds from ebay the other day into the gauge cluster. so the problem is when I first put them in they all work fine for about ten min, then all the suddenly the two over buy my temp and gas gauge go out. im really confused why those are the only two that go out. any ideas why? the leds are 194s with four leds per. any help would be appreciated.
Probably just crap LED's. Superbrightleds.com has the good ones and even those go out more often than normal bulbs.
Try led wholesalers they are the shiz. Ebay bulbs are made poorly the contacs break or move away from position.
The ones im talking about have the contacts mader of solder so they wont break or move.
Sent from my Samsung Galaxy Note 2 like a boss!!
there is also polarity to the LED bulbs even tho they twist in either way, try turning the bulb 180* and installing it
NEWBIE
i did that i think they were just really cheap leds, because another went out today. ill just try buying the more expensive ones.
NEWBIE
The ledwholesalers 194s look way different will they still work? im used to seeing the ones like on superbrightleds.com
Led Wholsalers:
Dimmer all the way down
Dimmer all the way up
Also all the 74 bulb were replaced with their bulbs such as the odometer bulb, hi beam, turn signal indicators, and the cruise control which is on ib the pictures also all the warning lights.
Looks like the LED's magnify the hot spots. I have regular bulbs in my cluster and I have similar hotspots, yours are very visible Vic.
-Greg
They seem more pronounced on the pictures than in person. But yea I just ignore it.
NEWBIE
ok thanks guys for all the info
