Thread: 2g turbo exhaust manifold
Showing results 1 to 5 of 5
    hi guys! will this work on 7g? its from the turbo 2g eclipse. or do i need to get from the non turbo? thanks
    link...
    http://www.sulit.com.ph/index.php/vi...haust+manifold
    you need to search the forums go to the 7g performance section you will learn many things
    Me I'm a lil of both
    08-13-2008
    Waterbury, CT
    3,331
    if you are going turbo it works great. if not you need a 1g 2.0 header and then modify it to work with your current exhaust. you can't use a 2g non turbo header as they have a 420A which is not even close to our motor.
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    I gave him a little spoon you airplane-d it lol
    indeed this info is correct if you are going to work on your car
    get familiar. there is much info here but this is an old site and
    like any old library you must be diligent in your quest for info.
    also if there is a junkyard nearby go as often as possible and
    seek out interchangeable part ...of which there are many. I
    recommend you read the build threads as you will find everything
    from swapped oem steering wheels to awd conversions.
    good luck
    ok thanks guys i'll check the forums. btw i'm from the Philippines.
