Thread: O.O Potencia 6g75 Mivec Triple TB's
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 41
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    This is the same Mirage 6g75 swapped that had 330whp with a single TB lol (links are to facebook hope they work)
    Quality isn't on the camera but under the hood:
    http://www.facebook.com/photo.php?v=10152735167215455&set=vb.620500454&typ e=3&theater
    http://www.facebook.com/photo.php?v=...type=3&theater
    4g64T 5spd
    TGC Regular foxbrand's Avatar
    06-18-2011
    chicago suburbs, IL
    600
    sweet god
    really obvious question, I'm going to guess that this could only be used with a speed density set up with a piggyback, is this correct?
    All that's going to do for him is make it impossible to drive on the street. 1000rwhp supercharged drag cars run three throttle bodies like that. An appropriately sized single plate would suit him better, it's not going to flow more air if the engine is satisfied.
    12-13-2010
    Brooklyn, Maryland
    4,643
    The links work for now. I saved them to my computer, I'll upload to youtube if they stop working. Looks crazy! Wretched excess, gotta love it.
    -Greg
    05-03-2009
    1,465
    Quote Originally Posted by foxbrand View Post
    sweet god
    I really don't know the details it was unveiled yesterday on that video
    I'll update on monday or tuesday since the car is making its debut with this setup in a drag strip match against a also high powered honda civic hatch named "La Rabiosa"
    It was running 11's and putting down 330whp with a single 90mm TB so we'll see with this setup
    4g64T 5spd
    All motor LS blocks make 600 at the wheels on the 90mm. What a joke.
    That said, someday a big block mirage might have to happen.
    They appear to be fond of "Silvertune Blue"
    05-03-2009
    1,465
    What kind of comparison is that?
    A big block mirage would be interesting...
    4g64T 5spd
    06-18-2011
    chicago suburbs, IL
    600
    he's referring to 6g74's and 6g75's as big blocks
    Just because something is old, doesn't mean you throw it away
    Geordi La Forge
    05-03-2009
    1,465
    I think he is referring to chevy big blocks and that would be interesting, 6g74 and 75 have been done already
    4g64T 5spd
    He's talking about personally building a 6G75 Mirage, I strongly believe. It's a project he has mentioned a few times.
    Yes... Big block Mitsubishi refers to the 6g74 and 6g75, because they are the big block V6's...
    And it is a noteworthy comparison because muscle cars can pull 650hp worth of air through one 90mm throttle body. The 3.8 was making maybe 400 crank... it has a lot of breathing work to be done before an upgrade and all but making a door out of the back of the plenum isn't going to do it.
    05-03-2009
    1,465
    So the car made 10.6 132mph and 10.5 133mph and won a couple of passes against "La Rabiosa" which is a Turbo 1.6 Civic Hatch with around 600hp
    4g64T 5spd
    Nice! Even though the 8G is heavier, it's pretty damn sweet to see a N/A 6G75 push into the 10's regardless of what Mitsu it's in. I want to see video of this thing in the 10's when they release it.
    06-18-2011
    chicago suburbs, IL
    600
    ^second that
    I would love to see a dyno video of this thing as well
    I'd just like to know how they get MIVEC running with the Montero ECU's.
    06-18-2011
    chicago suburbs, IL
    600
    if memory serves, that thing is using a standalone
    Geordi La Forge
    I'm sure that one is but they're run mostly with Montero ECU's according to a couple guys I've talked to. None of them knew exactly how the wiring worked with Mivec however.
    05-03-2009
    1,465
    At the moment there's not a single video yet with a clear view of the times, as soon as there is I'll post it.
    And about the MIVEC SPD_FRK posted on GT that you can control it with our ecu, you use the EGR wiring and pin to control the oil control valve and then find and define the EGR table on your rom, I don't know if this is how the mirages do it.
    4g64T 5spd
    Yes I am well aware of the EGR. Like every single thing spd frk ever attempted however he never actually proved it worked and based on his extreme level of failure I'm not about to drop 2k on a swap based on his word.
    Someday perhaps. The MIVEC motors could use a set of cams just as much as the non mivec motors could. Both are spendy so your starting point is not as important. That said a MIVEC with a 264 base profile would be pretty effective in the output department.
