Thread: awd swap help!!!
Showing results 1 to 2 of 2
    awd swap help!!!
    i have done a awd swap to a 2g eclipse turbo and im wanting to know if it is as straightforward as that!! does it all bolt up besides the gas tank and the subframe?? i live in a apartment and can't have a parts car here and i don't have anywhere i can store it so i will have to pull the galant rear end out and but the eclipse rear end in and keep it fwd for the moment, until i get the rest of the parts.. i have a chance to get a great deal on a awd parts car right now but can't get it until i know that the rear end will go in with all the eclipse parts or will i need and evo parts to finish the rear end install....
    You are unbelievable… YES THE ENTIRE ECLIPSE 97-99 GSX “AWD” REAR SUBFRAME WILL BOLT UP TO AN 8G GALANT REAR. PROVIDED THAT YOU WILL INSTALL NEW BOLTS THAT HOLD THE SUBFRAME TO THE BODY. YOU WILL HAVE TO CUT HOLES IN YOUR TRUNK AND IN THE REAR WHEELWELLS TO DROP THE NEW BOLTS IN.
    EXAMIN MY BUILD THREAD: https://www.thegalantcenter.org/show...!!!&highlight=
