Thread: Need some gauge wiring help
Showing results 1 to 3 of 3
    Icon6 Need some gauge wiring help
    I am wiring up a custom gauges set up and i need some help identifying some pin numbers and wire colors from the ecu/pcm for the water temperature, gas level, tach and speedo.
    I have used the search on this thing and cannot find anything on it.
    Please help me out because i would love to finish this up.
    I remembered seeing a few wiring diagrams when looking into apexi a/f controllers a while back, did a quick search:
    http://www.apexi-usa.com/manuals/ele...afc_manual.pdf
    start at page 37 and look for the info on your ride then jump down to 47 and start looking for ECU diagrams
    Hope this helps!
    if not, don't be afraid to search around on other sites too =] as awesome as this site is, http://www.club3g.com/ also helps out a ton once you figure out what all is the same with 3g eclipse and 8g galants
    Hope this helps!
    Also, if you don't know what all crosses over then def start looking up on that before starting any project, in the searching you can find a LOT of helpful info on others projects
