Thread: wideband logging
Showing results 1 to 5 of 5
    wideband logging
    Those who are logging. where are ya tapping to for the 0-5v output? I'm using aem uego.
    i dont think u use the white wire,i gotta look at mine again
    STAY READY AND YOU WONT HAVE TO GET READY!!
    Analog does nothing. You need to use the blue signal wire with a serial plug then a serial to USB cable to the laptop with Evoscan. It's all over evom on how to do it.
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    4g64T 5spd
    Its the white wire to pin 8 on dlc and and the blue get left alone.
    I'm using Tactrix 2.0. And uvtune software.
    Ecuflash is not compatiable with the 9g. Uvtune is successful on the 4g eclipse but having so much problem with mine
