Funny question coming from a guy your name... But the shop probably meant that you need bushings and maybe Swaybar links
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Good Afternoon Everyone....the local Midas said I need a "sway bar kit". Is this the same as the Suspension Stabilizer Bar Link. That's the item that pops up when i did a search on rock auto. and is one bar for the entire front end or is it necessary to order 2 ?
Thanks
Sway bar end links. Be careful when ordering aftermarket ones with the grease fitting. Don't don't last. OEM are better.
