Thread: Time for an Oil Change
Showing results 1 to 20 of 20
    Experienced TGC Member Lazarus's Avatar
    Jacksonville Florida
    1,409
    Hey all With th changing weather it's about that time to change the oil type as well. Which Oil grade are you all switching to?
    C.J. Cameron
    RETIRED TUNER!!!!
    "Keeping it Simple"
    Faction
    im switching over to 10W30 starting Mid-May, you know Laz, the florida weather. oh and i almost forgot, is it safe or is it good to mix one bottle of synthetic blended oil with regular oil?? i just had that idea in my mind and thought somebody knew my answer
    I am using 10W30 Mobil 1 Synth.
    Love,
    Matt
    i'm using the castrol blend!
    Semper Fi'
    09-22-2002
    Kissimmee, FL
    1,495
    <div class='quotetop'>QUOTE(VegasMatt)</div><div class='quotemain'>I am using 10W30 Mobil 1 Synth.</div>
    Using the samething..
    1,409
    <div class='quotetop'>QUOTE(Punklant_03)</div><div class='quotemain'>im switching over to 10W30 starting Mid-May, you know Laz, the florida weather. oh and i almost forgot, is it safe or is it good to mix one bottle of synthetic blended oil with regular oil?? i just had that idea in my mind and thought somebody knew my answer</div>
    No Don't mix Synthetic and regular. you'd be better off with the half synthetic mix. Once you go Synthetic your not suppose to change back
    C.J. Cameron
    RETIRED TUNER!!!!
    "Keeping it Simple"
    12-17-2002
    Sherman Oaks, California
    4,304
    <div class='quotetop'>QUOTE(Lazarus)</div><div class='quotemain'><div class='quotetop'>QUOTE(Punklant_03)</div><div class='quotemain'>im switching over to 10W30 starting Mid-May, you know Laz, the florida weather. oh and i almost forgot, is it safe or is it good to mix one bottle of synthetic blended oil with regular oil?? i just had that idea in my mind and thought somebody knew my answer</div>
    No Don't mix Synthetic and regular. you'd be better off with the half synthetic mix. Once you go Synthetic your not suppose to change back</div>
    yeah, as long as you start putting synthetic into your engine from day 1, you're ok. if you've been putting in regular, then synthetic, its pointless. i get a lot of people that come into the shop and insist that i put synthetic oil into their car when they've been running something like 5-30 or 10-30. people in san diego think they know everything
    http://socallifestyle.com/
    1994 Galant GS 5spd
    Senior TGC Member
    2,175
    They say you can always switch back and forth between synthetic and regular...at least, that's why everyone tells me. I'm using 10w30 for summer, 5w30 for winter.
    Faction
    Quote Originally Posted by Lazarus
    Quote Originally Posted by Punklant_03
    wow, it says Punklant_03 still in that quote, he is no longer here
    Tiptronic
    do the synthetic oil come in the different viscosity's as the regular oil (5w or 10w) or is there just one base viscosity with that
    Senior TGC Member
    2,175
    Quote Originally Posted by SGT Bilko
    They still come in different visco
    Tiptronic
    Quote Originally Posted by Phyxsius
    okay cool. so even with synthetic, its 10w in the summer, and 5w in the winter :?:
    Senior TGC Member
    2,175
    That's the plan I stick with. Higher visc in summer to prevent the oil from getting too runny, and low visc to keep it fluid enough. My dealership automatically does this without input.
    mbssbm
    I'm using Royal Purple 10w40. If you haven't ever used royal purple then your missing out.
    Faction
    thats what i plan on doing with our galant, he used 5w without a problem during winter time, 1 question, do i have to keep using the synthetic blend in the engine or can i use it and then use regular oil after the synthetic? the blends im talking about is the ones that aren't fully synthetic, i just wanna get it straight
    Tiptronic
    Quote Originally Posted by mbssbm
    some talked about this royal purple on th old boards. said it was great, but pretty hard to come by. not everybody sells it. i wonder if they got a webite......?
    1,409
    I made the swap to Amsoil 10W40 before I made my drive down to Florida haven't had any problems with it so I must be doing good.
    C.J. Cameron
    RETIRED TUNER!!!!
    "Keeping it Simple"
    Faction
    why 10w40?
    1,409
    no reason in particular its synthetic I try and keep it amsoil and tat's all the shop had at the time and I didn't wanna wait to order it. Check your PMs by the way
    C.J. Cameron
    RETIRED TUNER!!!!
    "Keeping it Simple"
    SB99
    Im actually using 0W30 Amsoil Synthetic in my 99 Galant. I think Amsoil is pretty good.
