edit totally misread your post. my bad.
What should the fuel pressure be on the 2.4 engine? I'm testing it in a minute to diagnose a misfire when accelerating from a stop. I did a search and I couldn't come up with a number.
no worries I had no way of checking the pressure any way because the Orielly pressure testing kit could not hook up to the fuel lines. Apparently most other cars have a pressure testing valve or a "schrader" valve to plug pressure vales onto. Not this car! But I found my problem any way. still curious what the pressure should be though. my fuel pump has 200K on it and it's still going.
What was the problem I'm having same issue kinda stumbles missis at low rpm from stop between 1000 and 2000 rpm changed coil packs, plugs, cables, still doing same thing maybe its the tps or the fuel pump or regulator can some one guide me in the right direction I'm very mechanically inclined just can't seem to wrap ma head around the problem
48 psi with the vacuum line disconnected
