Thread: Prothane 4 cyl front control arm rear bush
Showing results 1 to 18 of 18
    TGC Regular bgood12's Avatar
    07-17-2009
    554
    Well the kit for the 3g eclipse from prothane is great, but the seeing as I have a 4cl cyl the bushing on closest to the rear of the car on the front control arm did not fit. The bushing for that part in the lot is large and for a 6 cyl engine. I believe the 6 cyl bush is 62 mm in its midsection and the 4 cyl rubber bushing I took off the car was nominal of 50 mm but I had to take a little more off cause prothane does not compress like rubber. So I did about 49 or 48 mm.
    Here are the two side by side
    The lower one is the one I sanded down notice how it's sanded to about halfway between the part numbers. The upper one you can still see the whole part number.
    I was going to use a lathe but after talking with the shop guy at my school who had just done some work on a prothane mount told me a sander would be better cause the material does not take to a chuck well well and the angle of the cutter has to specially set up.
    Here was my setup with a belt sander.
    While putting this in make sure to check that your bracket fits the same way as it did with Th e rubber bush, otherwise you could break the threads on the control arm bolt or chassis hole thread as I did. A night of Cussing and screaming later I retapped the hole and was good to go.
    Car does feel great with prothane, happy I stuck it out.
    Sent from my SGH-T999 using Tapatalk 4
    11-29-2009
    Chadds Ford, PA
    2,768
    Uhm you got the wrong set. The control arm designed was changed after 2001. That's why the bushing is off.
    07-17-2009
    554
    Yea I figured but I could not find what set to get I searched on here for part number and prothane site is vague which set is it
    07-17-2009
    554
    It could also be that my car is an old chassis as its a 2000
    07-17-2009
    554
    Or do I just get the v6 bracket for that rear part
    11-29-2009
    Chadds Ford, PA
    2,768
    It has absolutely nothing to do with v6 vs I4 as they have the same control arms. Its that you car is older than the kit you ordered. Plain and simple. Look on club3g as there is a whole discussion on this.
    07-17-2009
    554
    Its all good kit says 00 to 05 so maybe I should get 94 to 99 o well what's done is done ill just do the other ill look and see if I find the discussion but google searches got me nothing , but I was at work thanks ill keep looking
    07-17-2009
    554
    Also, I had to do soemthing causebim in kc four days a week and back in topeka Thursday through Sunday, so I had already broken the old ball joint boot so I had to make something work
    Looks like they have different part numbers, so they are not the same:
    I4 :
    MR455738 ARM ASSY,FR SUSP,LWR RH 02.01.1998-01.02.2001
    MR554376 ARM ASSY,FR SUSP,LWR RH 01.03.2001-07.03.2003
    V6 :
    MR369792 ARM ASSY,FR SUSP,LWR RH 02.01.1998-04.03.1999
    MR369796 ARM ASSY,FR SUSP,LWR RH 05.01.1999-05.03.2000
    MR554376 ARM ASSY,FR SUSP,LWR RH 06.01.2000-06.03.2002
    MR554376 ARM ASSY,FR SUSP,LWR RH 07.01.2002-07.03.2003
    07-17-2009
    554
    Thanks
    07-17-2009
    554
    I have DE as well and 2000 had different part I know that I have v6 on the way but don't know if it will fit
    07-17-2009
    554
    Mrg I tried to message you but I found the page on club 3g but never saw a definite answer. I'll look again
    11-29-2009
    Chadds Ford, PA
    2,768
    Read this thread in its entirety
    07-17-2009
    554
    I did I read them all and the energy suspension part the picture still shows the new style arm so I dunno what linlin did other than get the oem bushing it's fine I'll just sand it down it seems to be working fine
    11-29-2009
    Chadds Ford, PA
    2,768
    Quote Originally Posted by GalantES-2001 View Post
    I4 :
    V6 :
    Look at the production dates you listed. Non of them match up. They are the same the v6 and i4 have the SAME EXACT CONTROL ARMS!!!
    The only ones that are different is the year change from mid 2001 and up with different control arm mounting points and bushing design. Not v6 vs i4
    Quote Originally Posted by bgood12 View Post
    You wasted your money on buying a v6 bushing.
    I just went out and looked at my master bushing set and it seems that Energy suspension messed up on years and bushing design. I am going to call ES up tomorrow and see what the deal is. The bushing set that will work for it is $50 bucks. Not worth it considering I just bought the compelte set and they screwed up.
    Why do those dates have to match up? The last version of the control arm (MR554376) went to production on 06/01/2000 and appeared on V6 models first. I4 has a different subframe, so they did modify it first and then used the same control arm on I4 models, produced from 01/03/2001.
    Maybe you are right about the "ARMS", they are the same and the only difference is bushing and mounting points. But the arm doesn't have a dedicated part number, Mitsubishi sells the whole assembly. So, if the car (2.4 engine) produced after 03/2001, we are lucky: there is no any difference between I4 & V6, they use the same assembly. If the production date is before 3/2001, we need to choice the correct assembly, bushing & etc.
    11-29-2009
    Chadds Ford, PA
    2,768
    I give up.
