Thread: Where does this tube connect to?
Showing results 1 to 3 of 3
    ZiplokeR
    I can't find where this tube is supposed to be connected. Anyone know.
    It's a 2003 galant, 2.4l
    Thanks.
    Sent from my SGH-T889 using Tapatalk 2
    I think the manifold. but it might go to the EGR system... I can't fricken remember. I know its a vent tube that goes to the fuel tank, so I'm thinking egr
    ZiplokeR
    Thanks, I found it with the help of the vacuum diagram.. It's hard to see from the top.
    Now the only problem I have is rough that idle only when ac is on.
