Thread: Official Introduction - 1994 Galant GS-x AWD
Showing results 1 to 20 of 29
    Hello TGC,
    It is time to "show off" my 94 Galant for the first time in its full glory (its not a show case quality by any means). Those of you, who have had followed my build thread, know that I have been working on the car for the past two years and it has swallowed pretty much every dollar that I've made. It has been a pain and a joy to work on the car and do the modifications I wanted to do, but the result is here and Im very happy with it. Biggest thanks goes to me for not giving up and pouring more and more funds into it, and of course all TGC members for the support I received and last but not least is TGC for having my project thread on here and the tremendous amount of info that is on here.
    Big thanks goes to Eclipsh for pioneering the AWD swap, and the other 7g members who were going along with the swap at the same time as I did - Phizzlot and w/oarctic7g; Galanttuner10 for providing me with the GS shell; Chaotic Coating (Alex) for doing all the powdercoating for me in some crazy cold late nights, my buddy Shawn who housed the Galant for two years and my girlfriend for putting up with me...........oh shit I dont have a girlfriend cuz I bought this car......oh well; and not to forget the DSM community where I found answers to most of my questions.
    Current mods
    Engine:
    -bottom end
    2.4L with 97k miles, honed walls, stock pistons/rods
    ACL tri-metal race bearings
    Balance shaft eliminated
    Gates racing kevlar timing belt
    Urethane Filled motor mounts
    - top end
    60mm TB (1g N/A)
    6-bolt Big port head +minor porting and polishing
    OEM brand new valves
    Viton valve seals
    Brian Crower valve springs
    6g vr-4 stock cams
    OEM 94 GS cam gears
    3mm lifters
    OEM head gasket
    - forced induction
    8 blade HX-35W @12psi with BEP .55 bolt on housing - 4an with .065'' restrictor for a the feed, 12an drain line
    BEP cast manifold
    38mm Tial MVS (recirculated)
    Hallman Pro boost controller
    FP 4'' intake pipe
    Spektre Filter
    Punishment Racing BOV (recirculated)
    Ebay FMIC 12 x 28 x 2.5 size
    Vibrant IC couplers
    Napa t-bolt clamps
    - fuel
    rewired stock fuel pump
    fuel lab 8an fuel filter
    8an feed and 6an return fuel rail adapters
    Fuel management
    Stock ECU with boost referenced SAFC.
    Drivetrain:
    Stock 96 Talon Trans and transfer case, LSD rear differential, extended stock 3 piece driveshaft
    Fidanza 2300 pressure plate
    Fidanza 8 lbs. flywheel
    ACT 6-puck sprung clutch disc
    Short throw shifter made by ME
    Symborski shifter base bushings
    Aluminum shifter cable bushings
    brand new seals everywhere, brand new axles, brand new OEM shift fork, pivot and TOB
    Exhaust
    Evo3 o2 housing
    3'' turbo back exhaust
    Vibrant high flow cat
    18'' + 36'' Cherrybomb glasspacks
    Dynomax muffler
    Suspension
    Kyb AGX 2g front shocks with stock 2g GSX springs
    Kyb AGX 4g rear shocks with stock 2g GSX rear springs
    Prothane suspension bushings
    - Rear
    3g upper and lower rear control arms
    2g Diamante rear trailing arms
    Custom rear toe arms
    22mm Addco rear sway bar
    - Front
    Generic Strut tower tie bar
    Camber kit
    21mm GSP front sway bar
    brand new front control arms, tie rods and bellows
    Brakes
    ABS eliminated
    95 Eclipse non-ABS prop valve
    SS braided lines all around
    3g master cylinder and brake booster
    - Front
    05 Outlander calipers + brackets, OEM Outlander rotors, OEM pads
    - rear
    early 95 Eclipse calipers+brackets, early 95 Eclipse rear vented rotors, EBC green stuff pads
    Interior:
    2-toned interior
    Full leather salon - 98 Sebring front seats, 96 Galant S rear seat
    3g steering wheel
    3g shift knob
    Custom round shifter trim
    8g Galant tan floor mats
    Pioneer headunit
    Dyed carpet
    Gauges
    AEM wideband
    Autometer Sport Comp Boost gauge
    Autometer Sport Comp Oil Pressure gauge
    Fuel pressure gauge (in engine bay)
    Exterior:
    JDM head lights (big thanks to my sister for shipping them from the UK)
    JDM Diamond Edition Tail lights
    JDM Diamond Edition front bumper/grills
    JDM Diamond Edition high rise spoiler (not installed)
    02 Lancer OZ rally edition side skirts
    brand new inner fenders
    Evo 8 Enkei Rims
    235-45-17 tires
    It all started with a lot of jealousy of Eclipsh' Galant and it ended up with me acquiring 96 Talon AWD parts for $1000. At first, I thought I was gonna swap my red Galant since it already had forged piston engine and big brakes and stuff, but then when i thought about it, it was my only car and I couldnt afford to not have a daily. Then I saw Galanttuner10's ad, selling the green GS and the plan came together. The car didnt come with an engine, transmission or pedals and shifter, which I knew about. It looked pretty beat up from sitting under a tree for around 6 months.
    So here it is 1994 Galant GS-x AWD swapped being on the road for two weeks.
    DSM stickers on it to make it legit
    Engine bay
    Dont notice the two MAF sensors, I need to weld a pipe instead of the GM sensor
    Under carriage
    And my Galant with his less-evil twin
    Seriously, I dont know who the car belongs to. This is the first time I see another G besides mine in a long time.AND the pictures show why 7g never made it big in the USA.lol
    Awesome work, been following your build for quite sometime and let me tell you that I'm jealous hahaha will probably do the same to my GS once it becomes my toy instead of my daily which I hope is soon enough. :-)
    I Like! Vids!
    12-13-2010
    Brooklyn, Maryland
    4,643
    Chris, this is awesome! She looks very good and I can't wait for vids as well!
    Amazing seeing a stock one in the same color, you definitely see why they didn't catch on. If only the world-spec was sold here!
    -Greg
    This looks awesome man! I can only hope to have my GS be just as good as this one!
    Also x2 on the vids.
    1994 Galant GS - Daily driver
    1994 Galant LS - Parts car
    Garage: http://www.thegalantcenter.org/garag...iew-20241.html
    03-16-2010
    Maplewood, NJ
    1,290
    Good to see its on the road
    13 Honda Accord EX 6MT
    03-16-2010
    Maplewood, NJ
    1,290
    You gotta get some footage of you sliding that thing around when the snow hits the ground!!
    CONGRADS! Nice work!
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    Looking good I hope you have fun with it!
    Awesome work dude looks like it came from the factory the way you have it!
    Jigz-TGCIL Sosick Motorsports
    This one is so clean! Great job man. How does it sound? Looks like you have a cherry bomb resonator on it =)
    Do you still have the red galant???
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    Thanks guys, I appreciate the kind words.
    Its quiet while cruising, but it def has some deep tone to it. There are actually two cherrybombs on it lol
    I do have the red galant and Ill be tearing in it very soon. I have the idea of turning it into a race car and guess what it will be AWD swapped too.
    beautiful, good job.
    You did an amazing job! Happy for ya man.
    7g Dirt Racer- 95 Galant- 4g64,5speed swap, external coil, dohc swap, 60mm t.b., b.s., a.c., p.s. delete, battery relocate.
    7g Street- 94 Galant GS- 2.0 4g63t, awd conversion, auto swap, 98 gsx ecu, fmic, maft, bs delete.
    3g 00 eclipse gt 3.0 at
    Ohh didn't notice the second one lol. You'll have to shoot a video so we can all hear it!
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    Where did you get those AWD stickers?
    08-18-2004
    Charlotte, NC
    1,029
    Awesome!
    1994 GS FYI
    DSM/CSM Manuals
    Wow, this is awesome! Another great example of hard work and dedication. Definitely shows the potential for the 7g
    Good work!
    The other Galant needs to learn how to park
    08-13-2008
    Waterbury, CT
    3,331
    Awesome job man. Congrats.
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
Tags for this Thread
