get prothane mounts. you have to pop out the innards of the mounts you have and install those in the front and back, you can do all four but you will get more vibration.
Hello Everybody,
Does anybody have any recommendations on a specific brand or type of motor mounts that will last me more than one year. My front and rear motor mounts keep breaking on me. I have tried two or three different brands. I do drive hard. I try to refrain from accelerating to fast from a stop but they still keep breaking around 9-12 months of use. any tips would be greatly appreciated.
Thank you,
Rami
^^^^ what Dom said. heres the links for some depending on your engine type
http://www.ebay.com/itm/2000-2005-Mi...839f5e&vxp=mtr
http://www.ebay.com/itm/Prothane-Mit...b5a8e2&vxp=mtr
very cheap and worth the buy.
OEM from oemmitsubishiparts.com or Beck/Arnley from Rockatuo.com/ebay etc
I've heard good things about Prothane, but mainly if you have a manual if I remember correctly.
Here's a pick of mine, the side mounts are prothane inserts and the front and rear are energysuspension inserts, hardest part was getting the metals rings out, I tried cutting the rings out but ended up just using a press and pressed them out, I drive like i stole it and the mounts haven't broken since I upgraded them.
01 Galant ES V6 MT (sold)
00 Eclipse RS MT
A simple google search brings up http://www.prothanesuspensionparts.com/ and http://www.energysuspensionparts.com/ and those are the site I bought from. You could get the prothane front and rear inserts but prothane did 2 things wrong with the front and rear inserts, 1st they made the hole that the bolt go through too big so you have to sleeve the bolt and 2nd they put holes in the mount insert itself and the space between the holes can rip creating a bigger hole.
00 Eclipse RS MT
That problem was on the older Prothane kits. They have since revised them.
2017: 552whp/562wtq SBE on 19psi'02 Eclipse GT: 6G72 M/T-swapped Daily Driver'10 Endeavor: 6G75 AWD Family-mobile
my bad, I found the prothane site Black, but for some reason I ended up on a different site for the energy ones, hmm, I was not diligent enough, also thought there may be a site that you frequent for parts. Thanks to everyone. I am going to order the parts and hopefully not be bothered by these again! :p One last thing, I am going to try and get the Prothane kit for all 4 and hope that what M-rod stated about fixing that issue is correct!
The one thing to look out for is making sure you're buying the new revised kit and not some old overstock of the old version.
This listing is for the new kit which includes the cross member bushings as well.
http://www.ebay.com/itm/13-1903-Prot...d5e71b&vxp=mtr
M-rod, I sure was about to! lol, I'm not sure how often Prothane update their images on their site but they looked like the old ones. Glad you showed me this link! Thank you both once again! Onto the next post!
just in case anyone was wondering, New mounts are money, I only have the front and rear in, a little more cabin rumble while stopped in gear but it's worth it to me!
I've replaced mine twice and haven't had a problem since, next I'm definitely getting poly mounts
Black, Did your side mounts come in two pieces or were they solid units? the prothane set of 4 the left and right mount are two pieces that you slide in from each side then insert the sleeve. just wondering.
2 pieces, I found an old photo, the trans and passenger inserts are different sizes so if you're ordering just the side inserts from prothane make sure you order the right part numbers
00 Eclipse RS MT
Nice, were those easier to put in because they were in pieces?
yes, I could push them in with my hands, the front and rear I used a press.
00 Eclipse RS MT
I did 3 of the 4 on my V6 Galant using the red urethane. Had to drill the mount stud hole as I upsized the bolt. Too hard to add pictures or I would.
Just posting so I have the links for inserts... lol
