Thread: Installed new shocks and struts now get a banging noise
Showing results 1 to 9 of 9
    as the title says I installed new shocks and struts "kyb- gr2" and kept the original springs. I made sure everything fit perfectly and was torqued per spec. Anything I can check to see what it is? It does it mostly when I hit small dips in the road. Thanks guys
    Can you get a video recording? Pics of the installed strut/spring?
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    Did you put the rubber bump stops on the new shocks? You could be bottoming out. Other possibility is that you didn't get the nut on the top of the shock tight enough. I'd recheck the nuts.
    Quote Originally Posted by eclipsh View Post
    Hey, do you have a picture of what the bumpers look like? And I checked the nuts with my torque wrench and they were in spec.
    I'll try and get a video of it but I don't know how well you will hear the noise and do you want a picture from the wheel side or under the hood
    Also check your sway bar end links I have a broken one and when the car rooms to that side it hits the underbody.
    09-06-2008
    533
    Quote Originally Posted by 154james View Post
    Don't be afraid of the Google. It won't bite.
    http://www.partstrain.com/ShopByDepa...HI/GALANT/1999
    It goes on the shock shaft. All four should have one.
    I replaced both front sway bar end links because the ones that were on there were shit. I used prostop ones and greased them for shit afterward. I'm thinking about taking it to a shop.
    I reused the old ones that I had on it before and one of them was kind of beat, could it be that?
    04-08-2010
    Springfield, Mass
    1,225
    Get new bump stops it could be that
    «Carlos»
