Thread: 6A12 V6 engine firing sequence
Showing results 1 to 6 of 6
    Icon10 6A12 V6 engine firing sequence
    Hello,
    I need help if someone can share to me the ignition firing sequence of 6a12 engine.
    Im checking my spark plug cables if they are connected the right sequence.
    Thanks.
    Looking from the front of the car it should be
    135
    246
    135
    246
    thanks sir
    Sir MKO
    my car sparkplug cable connection
    246 rear bank
    531 front bank
    ignition transistor coil sequence 1-4-2-5-3-6
    is this correct?
    joseph
    Firing sequence is 1-2-3-4-5-6
    Yep that right. just checked mine. both running mates are of the same ignition coil. i think we have the same engine model and release date.
    Quote Originally Posted by westernspike View Post
    Ive followed MKO firing sequence and it seems my engine improves runs smooth performance.
    Front bank 531
    rear bank 642
    I think my 1st mechanic have done it wrong again to connect the right sequence. Its good to ask the experts.
