Thread: finald8t build ver 2.0
Page 2 of 7 FirstFirst 123456 ... LastLast
Showing results 21 to 40 of 131
    02-17-2011
    i live in sunny florida
    1,240
    been in bed ll day puking my brains out since last night and im finally starting to fell better, as for what you guys are saying ill look into it, i still need to get gasket kit.
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
    10-24-2003
    1,432
    I ran several events with a cracked top radiator tank and never overheated, it would stay cool at about a gallon low, wouldn't leak either! At least not until I decided to fill it up all the way.
    Get feeling better dude, it's warming up so all kind of crap is going around.
    www.gooichimotorsports.com
    12-13-2010
    Brooklyn, Maryland
    4,643
    Exactly, get better Joe.
    Marc, I had a couple embarrasing stop lights where the steam would start to vent, but I never had any temp problems. I never got above 210F according to my scantool IIRC, it was just barely into the 200's.
    -Greg
    Damn Joe feel better man. Wow you guys are lucky haha
    Sent from my HTC6500LVW using Tapatalk
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
    Possibly clogged radiator, stuck thermost, bad water pump.
    02-17-2011
    1,240
    Well i found the cuase. One of the exhausr valve is stuck open, due to a bent valve. Ill post pics soon.
    Sent from my LG-LS970 using Tapatalk
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    02-17-2011
    1,240
    Ok so here my hypothesis on what really happen. One of the lfters on cly #4 exhaust side got rock hard. Kept the valve open that it added to much fuel into the system and the 02s saw to much richness and leaned out the injectors to maximum. It got so hot, it burned all the valve seats. Ate away material on the head and made it get so hot it started to over heat and popped out a frezzplug in the head. And over heated and lost compression in the head due to burnt valve seats.
    Thats my answer.
    I will still be going over this carefully and will be checking rad amd tstat.
    New water pump (well semi new), T belt ext
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    02-17-2011
    1,240
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    02-17-2011
    1,240
    This is what i found in the resivior tank
    something tells me this is the original belt since 2003, same with the motor
    since i had so much room for activities i install my rear motor mount with inserts
    new felpro top end gasket kit i got from rock auto. 60$ shipped, compared to 120$ local
    cleaned up the engine bay and block and started to install the head and intake.
    this is the reluctor wheel, cam sens cylinder, what ever you want to call it
    when using a 99-01 head and installing it on a 02-04 you need to switch this out or you will get a cam and crank code same goes if you use a 02-04 head on a 99-01
    in short term use the correct cam sens thats the same yr as your car
    99-01 cam sens, reluctor wheel(top)
    02-04 cam sens, reluctor wheel(top)
    both side by side
    i do plan to go back and soder all my connections that i made, i left my power probe at the shop and wanted to fire up the car so this was a quit solution at the time.
    the the outlander intake and evo TB i also had to rewire it by switching all three connections, real simple if you know anything about electircal.
    here a video of it running, it sounds loud now but after it idleing for 45 min it quit it self down abit, now all i need todo is figure out my throttle cable do a oil change, finish the interior and do fix a few issuse with the a/c, put a few miles on the motor and trans and then the fun begins
    all back together and running like a champ
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    07-02-2011
    South Florida, by the beach
    1,076
    that was fast, nice job
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
    02-17-2011
    1,240
    I would of been done in a weekend but with a kit and family issues going on for the past 2 weeks i manage to make time to get it done.
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    good work man. Good thing you knew about the cam reluctor. I bought my G without knowing the head was replaced at some point. Had no idea why I popped that code. Eventually figured it out and it was a simple $30 fix.
    02-17-2011
    1,240
    Quote Originally Posted by CHICAGO_ONE View Post
    Not alot of people now about it. I have a neighbor who is a master tech ask me why he was getting these codes on a 3g awhile back. He told me he did a head job, and i simply showed him. And he was mind blown, he chased it for 2day trying to figure it out. I laughed at him handed him a beer and said "now you know" cone back the next day and handed me 50$
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    02-17-2011
    1,240
    havent done much to the new G in the past week, found out i have a bad wheel hub in the rear, and finalized everything under the hood, still need to finish the interior but that will be soon, more important thing is ill be going on vacation next week and ill be installing the turbo but for now heres some pics of the engine bay all cleaned up
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    07-02-2011
    1,076
    Nice, hopefully you can bring it July 19th to the St. Pete car meet so I can see/hear it.
    00 Eclipse RS MT
    02-17-2011
    1,240
    Quote Originally Posted by Black8GV6 View Post
    The goal is to be there with it and be turbo, i have everything ready. Just need to prep my old oil pan for oil return. Grind down the compressor housing so it wont hit the starter, and install it.
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Under the hood is looking clean..even better when that turbo is sitting in it
    02-17-2011
    1,240
    So i have a water and oil feed kit i got fron ebay. Its for an evo. Oil feed is a -4an line. But all the a.n. fittings i have i can run a -6 but ill be choking it down to a -4 for 10in. Will his be ok or should i run -4 all the way or -6 for my oil feed
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
  19. #39
    02-17-2011
    1,240
    Quote Originally Posted by finald8ta View Post
    Edit, http://pages.ebay.com/motors/link/?n...d=151260980980
    This is part of the kit. Its a -4 line. But i can run a -6 from my oil source to this line. Will this be fine?
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
  20. #40
    02-17-2011
    1,240
    well i got more work done to the G, turbo is fully installed, decided not to use an AFPR, still have a list of things to install, i have a deadline to have the car at my shop this friday to weld up the exhaust, parts are on order as well, and my boy alex talked me into using the evo oil filter housing,
    list of things need done
    install fuel pump 255 wally
    install oil pan
    install evo oil filter housing
    wire in guages
    mount fmic
    exhaust work
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
