list on whos all going to the fla beach meet july 19th
gallant
1skglnt
black8gv6
SNWFLK
duh2150
7any one else going? if you are going let me kno and ill add you to the list
ill create a facebook event that way we can keep in touch and all talk on whos meeting up with who,
MODS
5 speed swap
Eibach Pro Kit on GR2 Struts
Cold Air Intake
Outlander Intake Manifold
6G72 V6 Throttle Body
6G72 V6 Fuel Pump
Axle Back Exhaust (ebay)
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
Prothane Motor Mount Inserts
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
^don't worry about the height, just come to the meet
01 Galant ES V6 MT (sold)
00 Eclipse RS MT
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
ok guys i created a page. add yourself state where your from and plan on who you want to meet up with,
if you have other people coming great bring them with you
also dont forget to register on the AFM page and pay for food before july 12TH
http://www.xecofl.com/tickets/
https://www.facebook.com/events/2562...ming&source=49
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
The link won't work for me :c
Sent from my Nexus 5 using Tapatalk
Dang my bad I didn't check up on the thread. I want to get $800 for them, they are basically new. Selling the wheels too, those haven't had any miles on them just tires mounted and dismounted. Trying to get $500 for those.
Well i made a trip out to orlando saturday and had a great time meeting up with other galant owner.
On the way there i only had two issues.
Car will over heat if i do more then 80mph with the a/c on
And after long trips doing 80mph i loose oil pressure.
On the way home i took the long amd slow way home and i had good oil psi.
Oil i used thinned out since it go hot after a long drive
All in all. Need to run a thicker oil and not 5/30 and run an oil cooler
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
Not that it will make a world of difference, but do you think removing the weatherstrip for the hood near the wiper cowl will let some heat out? I mean its free lol. I did it to my car cause its not a show car and the motor got dirty prior to anyway. I just left small sections above ground wires on the firewall, and removed the rest.
I'm sure you'll need better solutions but maybe it will be extra insurance
Better solution would be to get a vented hoos
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
Turbo car needs a little thicker oil, remember oil goes through the turbo which is hot, 5-3 is already thin as it is and will only get thinner, switch to a 40wt or if in warmer climate 50wt, but first see how it does on the 40wt. You'll see an increase in oil pressure as well. As far as temps go, make sure the fans are working properly, turbo cars run hotter so it may be a good to to upgrade to that evo all aluminum radiator.
Fans do work. I plan to switch to rotella 15/40 because its on sale at walmart
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
True I just didnt know if you were big on the looks of one
Also since your going to walmart dont know if you wanna take a look at this stuff. http://www.hyperlube.com/c3/Super-Coolant-c8.html
I've seen it in the ailse with the coolant. Normally like with like the flushes and stuff
Maybe it would help if he put the rad cap back on...lolol
to best benefit from it you have to run water instead of antifreeze
got a few things in the works
next stage is suspension and brakes
rear disk swap and dual pot front calipers up front,
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
Tuning is fun.....
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
big radiator is required IMHO, also an oil cooler. I run Total 10 60 quartz in both of my turbo cars, stuff is fantastic.
I was told by a few members i dont need a oil cooler. If i get my hands on an evo oil cooler with lines ill add it(running evo oil filter housing), as for the radiator i have a evo one doing nothing. It will be getting installed this winter. Right now im working on getting all my brake parts and send them out for powder coating. Buddy of mine will be doing that for free.
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
