Thread: T.p.s
Showing results 1 to 4 of 4
    Jpw01
    T.p.s
    What is the setting for the TPS?
    .68 to .72 VDC with the throttle plate closed, and i think above 4.8 VDC with the plate fully open
    Sent from my DROID RAZR using Tapatalk
    If you're using evoscan it's 12.5-13.33% with the plate closed.
    here
    Attached Images Attached Images
