Thread: Trans Mounts
Showing results 1 to 3 of 3
    Trans Mounts
    Jus finished a 4cyl rebuild and I'm ready to drop the engine in. I already have the new tranny in but for some reason my mounts won't line up correctly. The front one keeps coming out tilted and the rubber insert is being pushed out to the right. Any tips as to which ones I should put in first or if I should jus drop the engine and tranny in together?
    07-02-2011
    South Florida, by the beach
    1,076
    I connected my trans mount to the engine bay first, then once that was in place I connected the trans to the trans mount. I connected the front mount to the crossmember first then connected the front mount to the trans. I had my engine and trans connected first, then I did the mounts.
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
    Thanks! Turns out the cross member was bent. Went to the junkyard today and slapped another one on and everything's kosher. Hope to drop the engine after work tomorrow
