Thread: 5 speed swap help
Showing results 1 to 7 of 7
    5 speed swap help
    alright so imma finally start getting the parts for a tranny swap, now i know theres a 5 speed swap so... whats all the parts i need for this. and is there a 6 speed swap possible if so what parts are needed for this.... for both swaps my budget is 1700 is it possible with this...
    In the how-to section there is a parts list and instructions on how to perform the swap. You may want to start there.
    07-02-2011
    South Florida, by the beach
    1,076
    5 Speed, if you can just go to a pick N pull and get everything you need. If you have trouble or need help ask questions on here. Depending on where you source the parts and if you upgrade to a light weight flywheel and stronger pressure plate you will be under your 1700 budget.
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
    search on the website!
    here's the link
    https://www.thegalantcenter.org/search.php
    07-02-2011
    1,076
    This is what I made for my swap:
    5 Speed trans and mount and shifter cable bracket
    Flywheel
    Clutch/pressure plate
    Manual Starter Plate (#1055A022)
    Shifter base assembly
    Shifter cables (# MR357824)
    Clutch pedal
    5 speed brake pedal (or you can cut your auto one)
    Clutch fluid line
    Clutch Slave and master cylinders
    Clutch fluid cup
    If you have a V6 then on your passenger axle bracket just take a drill and make your holes and littler bigger. I got the 5 speed axle but it would have been easier to just to drill the holes bigger.
    V6 Throw out bearing MR145619
    Shifter cables MR357824
    Rubber plugs:
    Service Hole MD747412
    V6 Fork Release boot MD747413
    00 Eclipse RS MT
    05-14-2010
    Coachella, CA
    5,954
    I spent about 500 including 2 different fluids. Used Pennzoil Synchromesh and didn't like it, shifts were to notchy. Replaced with Redline MT 75w-90 way better.
