Thread: will it fit
Showing results 1 to 7 of 7
    will it fit
    hi guys! do you have any idea whether this would fit the 8G?
    http://www.ebay.com/itm/00-05-MITSUB...45cdb8&vxp=mtr
    thanks
    02-17-2011
    i live in sunny florida
    1,240
    No. If you want to lower your ride get springs and struts. Or coilovers
    Sent from my LG-LS970 using Tapatalk
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
    depends...is your suspension the same as the USDM 8g or do you have the worldspec suspension for your car, which is the same as the 2g eclipse suspension. depending on that, will determine if it will fit.
    besides the fact if it will fit, is it worth it? no
    i have usdm galant. read on internet that springs from 3g galant will fit the usdm 8g, but i thought i should ask you guys. and QNZ, why it is not worth it???
    07-02-2011
    South Florida, by the beach
    1,076
    I know English is not your primary language so I will try to explain very easy. What you posted are called coil sleeves. As you can see they are very cheap. They are not safe at all. Not worth your life. They will fit but not do not get them. If you want to lower your Galant correctly then get a set of KYB struts and a quality set of springs. Or get coilovers like brand name D2 or BC.
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
    Yes they will fit.
    I have kyb on my car, not sure whether they are struts or simple shock absorbers (if it is not the same thing )
