Thread: 07 Galant GTS Windshield Water Issues?
Showing results 1 to 2 of 2
    Icon5 07 Galant GTS Windshield Water Issues?
    Seems to be I need to reseal my front windshield, but water when driving highway speeds was coming directly onto the dash of the passenger side from the front window. After I reached my destination, I could tell water seeped into the door panel / electrionics. What should I check/be worried about? I could hear the speaker crackling in the door from the issue but also I've been having random issues with my horn going off each rotation of the wheel at low speeds; trying to fix this issue if anyone else has had this happen?
    I don't think it's your windshield causing the problems. Start by checking out your door seals around the door and door glass, if the panel and inside the door is getting wet. Windshields usually wouldn't leak into your door. If you see water coming in from the top of the windshield then it may run into the dash some. Trying putting a hose on it and check the areas.
