Thread: Timing balance shaft
Showing results 1 to 4 of 4
    New Member BLOCK8732's Avatar
    10-08-2012
    Tappahannock Va,
    75
    wats going on TGC i was wndering how you would time the balance shaft in my 4g64 8g galant. So you get number 1 cyl to TDC then line the balance shaft with marks and stick the screwdriver through hole and if it goes through about 2 1/2 inches its timed. oh and do you have to time the rear balance shaft. thanx guys.
    i take it you figured this out since you posted a question on why it has white smoke?
    10-08-2012
    Tappahannock Va,
    75
    Lamp just making sure
    10-08-2012
    Tappahannock Va,
    75
    Lmao just making sure
