Thread: PaulO's 5G 4G64 DOHC Mirage LS Coupe
Page 2 of 2 FirstFirst 12
Showing results 21 to 25 of 25
  1. #21
    1997 Mirage DOHC NA 4G64
    2003 Galant SOHC 4G64
  2. #22
  3. #23
    Quote Originally Posted by gtx View Post
    Now that's clean. Is that an EVO V rad?
    Thank You! Yes it is. Koyo for the evo 4-6. Fits the Mirage with zero problems, just requires the jdm top bracket if you want the OE look or you can choose to run only 1 bracket.
  4. #24
    So this happened 2 days ago. Luckily my block is ok, 1 & 4 have tiny knicks, but I'll take care of that for now.
    I
    Have a spare head as Well, but now I'm having an issue. HOW DO I TIME the head!?
    :( like 99 percent of pics online are dead links. If anyone has a pic just showing my how the gears should be, I would appreciate it. I need to remove the lower cover in a few days (work) I think something failed down there. The belt was only 1.5 years old. Very unexpected.
    - - - Updated - - -
    It's been so long since we assembled this motor that I forgot:(
  5. #25
    08-18-2004
    Charlotte, NC
    1,029
    its not that hard to do. like riding a bike.
    1994 GS FYI
    DSM/CSM Manuals
