Thread: Demond0d5 Daily Driven Project
Page 7 of 11 FirstFirst ... 34567891011 LastLast
Showing results 121 to 140 of 219
  1. #121
    03-12-2012
    Manvel Texas
    1,171
    Cool.
  2. #122
    got the bags/struts out today which was fun considering there is no way to get to that bolt that holds them on the bottom with anything other than a ratchet...and when you put any torque on it to break it loose the whole damn assembly moves...ended up putting the jack under the hub so it wouldn't move. also got the drivers control arm out, passenger's has to be cut of course cuz the bolt is rusted in tight...battery on the sawsall died before I could get it out...should be getting everything put back in on the 26th, gotta wait for the bags to get here from cali =/
  3. #123
    Laid a bit more fiberglass today since I was able to get more resin earlier...not much else I can do without getting it on the car...but thankfully I should be putting the bags/control arms back in on Christmas Day =D
    Pending the arrival of my parts of course...
  4. #124
    New bags:
    Compared to old:
    Control arms and bags in:
    And the newest addition, getting bolts tomorrow to do the shortest throw option:
  5. #125
    03-12-2012
    Manvel Texas
    1,171
    Nice dood.
  6. #126
    TGC Lifetime Patron Palmz's Avatar
    04-14-2011
    Iceland
    533
    looks good
    2001 Galant 2.4 USDM
    Old ones
    2X BMW E34 Blaaackkkk
    Isuzu Trooper mountain spec
  7. #127
    Was having issues with the cable on the passenger side jumping out going into 2nd and 4th so I hot glued it down...hopefully that'll hold it in place because I don't want to use anything stronger so it's still easily removable.
    Got the car back on the ground and my buddy at dodge is gonna help me run an alignment tonight once they close =D
    Next step is to find some new tires for the 17's that are a little narrower so I can get those back on!
  8. #128
    Sneak peek at grill idea
  9. #129
    07-12-2007
    SoCal
    4,632
    WarmSCSI spent over $50k IIRC trying to get the supercharger 6G72 to work. He went through multiple engines blowing and numerous headaches. I believe he finally went turbo and never looked back. I remember because I was here to see it all, IMO don't even waste your time with it. Go turbo if you want to keep your 6G72, or do the 6G75 swap. You'll be happier in the end.
    JDM Zenki Conversion
  10. #130
    What's the issues with running 5psi...I'm not trying to be the fastest, hell I'm not even trying to be fast. I just want to get it in and make it work, even if the performance gains aren't "worth it" or the most optimal for the money. To me it's more about saying "I have this and I did it"
    I want something I can play around with from time to time and work on in a few years. If I start getting the itch for a serious build it would be a 4cyl turbo setup...possibly AWD swap and a lot of fab for a 2 door...idk
    I just can't see what the issues with the sds are that are so crazy you can't have a modest setup. The air coming in is going to be the same if it's from a supercharger or a turbo, so the engine is a constant variable. Only difference is how you make the boost as far as I see...sds will have the parasitic loss as Justin talked about but also "no" lag...
  11. #131
    If everything goes right I should be doing the ported lower 72 mani and ported upper 74 with the ported/rebuilt 74 TB this weekend =D
  12. #132
    04-14-2011
    Iceland
    533
    Say ported one more time !!! i dare you i double dare u mutherfukker XD
    Old ones
  13. #133
    They are lol justin gave em a real good work over XD actually look real nice and you can def tell where he widened everything up a bit
  14. #134
    07-02-2011
    South Florida, by the beach
    1,076
    ^sweet, show us some pics for now, don't tease us
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
  15. #135
    03-12-2012
    Manvel Texas
    1,171
    What a tease!
  16. #136
    Ight here ya go...everything before she went under the knife at around 11:00:
    Upper out at 12:00:
    Comparing the throttle bodies:
    (Will get a more precise measurement before the new one goes in)
    Lower out at 12:15:
    And the lower back in just in time for lunch:
    (Yes I took all the tape off before putting it in, left the top on to prevent contamination)
  17. #137
    Still not the best but couldn't find the micrometer...anyway, you can see there is a big difference though. Here is the upper:
    And my fab job for the egr:
    Last but not least:
    ^makes me want to go back to a chrome intake though :/
  18. #138
    04-14-2011
    Iceland
    533
    i just noticed that ure runnin 2 batterys... why?
    Old ones
  19. #139
    Because I have a 5000watt system and 2 air compressors...I have a high amp alternator that does the job just fine but if I ever need a little extra juice for the subs when cruising around (say the headlights, AC, air compressors, etc are all on) then I have it.
  20. #140
    03-12-2012
    Manvel Texas
    1,171
    I also run two batteries for the same reason. Where did you get your alternator? You have a link?
