Thread: Help changing control arms
Showing results 1 to 20 of 20
    Hello, I own a 2003 galant GTZ and my rear lower control arms need to be changed because they squeak when I go over bumps. I took a look at them but I am not sure how difficult the job is. Do I need to remove the stabilizer bar in order remove the arms, or can I just unscrew the three bolts and pull the arm out. Any help is appreciated thank you.
    http://www.ebay.com/itm/Suspension-C...0cc656&vxp=mtr
    this thing? there is only the 2 bolts iirc, one for the adjustment and one on the ball joint...the hardest part I had with it was the adjustment bolt was rusted solid into the bushing, broke the bolt head right off when I tried to break it loose (no pun intended)...had to cut the whole damn thing out! if your luck is like mine then it's a pain in the ass, if you're lucky and it comes loose easily then its not hard at all
    I changed them no problem, but the noise is still there. I'm gonna look to the shocks as the next culprit. Thanks for the help
    time for coilovers!!!
    or bags
    03-12-2012
    Manvel Texas
    1,171
    Bags all the way!!!
    You on bags too?
    03-12-2012
    Manvel Texas
    1,171
    Yes sir!! Rides nice and looks AWSOME!! Love it. But depends on what your plans are, track or daily. Mostly everything I've owned has been bagged or lifted. Full size trucks lifted and mini trucks and cars bagged. Live the looks of them when there tucking wheels and frame on the ground.My set up on the rear of the G is all custom, rear is bag over lower custom control arm and front is strut over bag.
    Nice to see another bagged galant on here! Was beginning to think I was the only one!!!
    03-12-2012
    Manvel Texas
    1,171
    Thought for a while i was the only one bagged also. Need some pics man!! What set up are you running ?
    Here just check out my thread:
    https://www.thegalantcenter.org/show...Driven-Project
    and feel free to post anything ya want on there or PM me
    03-12-2012
    Manvel Texas
    1,171
    What struts are you using on the your fronts?
    No clue. The bags were on before I got the car. I have modified or changed or fixed everything else except the bags themselves
    03-12-2012
    Manvel Texas
    1,171
    Sits a lot lower than mine that's why I was asking. I like the lower look she has going on!! That's how I want my front to sit
    Thanks =D
    When I slam it I lay frame (has her fair share of scratches too) on the front...I wish I could get the back to drop a little more but, with my subs, I'm already riding a higher psi than I want just to have a decent height
    What's your camber like? I'm trying to find a way to stop killing tires :/
    03-12-2012
    Manvel Texas
    1,171
    My tires wear good. I have the the camber adjusters that mount on the upper control arm , goes between the control arm and body. My lower control arm is custom built and I can also adjust my Camder with it.i have some pics on my post when I first join I think. If not I can take some more pictures and hopefully can figure how to put them on here for you. I usually set my rear pressure @ 70psi and front @60psi when I'm rolling. That's the pressure I used when I did my alignment.
    Ight I'll try and look up your stuff! I need an alignment because mine is fucked :/
    I cruise at 65 front and 80 back but I want to be 65ish all around. When I put in my new subs they weigh so much I had to bump it up to keep the ride height decent ^.^ still rides decent though, not a Cadillac by any means but I've felt worse
    03-12-2012
    Manvel Texas
    1,171
    My trunk is heavy too with the subs,amps,compressors and tank plus a spare tire . She rides like a cadi!! Lol. How Is your a strut bag setup in the rear?
    I've got 100lbs in subs alone, not to mention the boxes XD Plus the tank and all that stuff :p
    I honestly don't know anything about the bags, only all the other shit with the system. Probably tomorrow when I have a day off I'm going to jack up the car and do some poking around the transmission and will look then (if I remember)
    Quote Originally Posted by coconut View Post
    I found your post, ride is sick looking! I love it
    after seeing your pics of the rear (IIRC) mine is nowhere near that. I think its the same setup as the front (with the bag on top). I might be able to get up on some jacks tomorrow and poke around (need to look at some trans stuff anyway) and will be working on the bumper too...gotta love a day off right???
    03-12-2012
    Manvel Texas
    1,171
    Thanks, she's my baby.
