The problem is in the connector. The ground side is probably corroded, common on these cars, mostly on the headlight harness. But still very possible on the fog light harness.
My fog light on the passenger side of my 8g (03) is brighter than the driver...anyone else ever had this issue? I'm using regular bulbs...no hid/led/halo or any after market lighting...tried swapping the bulbs to the other sides, still the same.
Thanks... I cleaned my grounds but that wasn't the problem...turned out it was just the way they were angled one was pointing up high making it appear brighter...readjusted both and there good now
