Thread: Tire size?
Showing results 1 to 4 of 4
    Tire size?
    Hey guys I'm running the stock 195 65 15s now. I got 17" eclipse rims. If I get 215/45/17s will they rub? I want low pro tires but not sure what size I need...I want about a 2 inch sidewall to my tire. Advice would be appreciated! Thanks!
    Recommended/best fit is 225/45/17
    And just fyi the profile of the tire(height of sidewall) is in the dimensions..
    The second number is a percentage of the first number to determine the profile...
    Example 225/45/17 means the profile is 45% the size of the width 225 millimeter... make since? No? Fuck it...lol
    This is correct.
    Quote Originally Posted by juicejax View Post
    Yeah I know lol I just don't wanna get too small of tires so they don't fill up my wheel that good. Unless lowering it an inch or so won't be expensive..I'm looking for a low pro tire for my 17s so that the height of the tire will be a smidge bigger than the stock 195/65/15s
